Hi guys first post for me,im new to gtr's.I have just recently bought a r33 gtr from Adam at JEM.It currently makes 343kws at the wheels on 20psi.
My plan is to switch it over to United e85 with an end goal of 400kws at the wheels.IT has a precision 6266 turbo and other supporting mods.At the moment it has an 044 intank,i was thinking of replacing this with a walbro e85 450l/ph pump and replacing 750cc injectors with some bosch id1000s.
I have asked Adam at jem and he said in theory this pump should do the job,but has not personally done it.
Your thoughts guys or experiences would be great.I will directly wired this off the battery thru a relay to get good volts to the pump.I have used the search function,but could not find an answer.
From the last page of the RB26 dyno results thread:
forged bottom end
stock cams and valve springs
metal head gasket with ARP head studs
precision 6266 0.84 T4 divided rear
3.5" dump/cat back
GFB EX50 50mm external gate
1200cc injectors with walbro e85 pump
power fc d-jetro
409rwkw @ 26psi on Caltex eflex E70, at the limit of stock cams and injectors
At 13.5v and 40 psi rail pressure it advertises 430l/ph and on 12v at 40 psi it flows 375l/ph.I plan on running a direct feed to get near 13.5 volts.So at 40psi pressure should outflow 2x 044s.I was toying with the idea of the bosch id2200cc injs.Thanks guys
Not sure on that one piggaz,i think I will go straight with the bosch id 2200cc or similar brand.Car has haltech platinum pro plug-in,should handle the big injectors ok.Thanks guys.
Have a gander at my attachment.
I wrote a pretty simple spreadsheet for calculating and comparing different fuel systems for my car. Obviously it's to suit my setup but could be easily tweaked.
I have highlighted all of the cells you need to update then see sheet 2 and graph's it all out.
IE set the highlighted cell to your desired base fuel pressure. write out your hp and boost based off a close dyno sheet. in my case when it was tuned for bp98. and then fill in the injector flows and corresponding pressures.
with this info it tells me that my injectors are too small for me to convert over to E85 and keep my same HP. unless I either run a 70PSI base pressure or go about an 80% duty.
fuel calcs.zip
thanks ss8 gohan,will go with the e85 450l/ph pump.Still tossing up on the injectors.Tuner thinks 1000cc ids will do,but a lot of guys on here think the 2000cc are the go.Most suppliers will warrant the 1000cc with e85 but not the 2000cc,Will do some more research.Thanks all,for ideas and tips.
  • 3 months later...
    • I clean my wheels every time I wash the car, I also clean the barrels, the only product I use on the wheels is truck wash and a pressure washer, followed by (inset your chosen name brand) wash and wax, time per wheel is probably 2 minutes total, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, they're also great for getting in between the front guards and body, and tight spots in the engine bay ย
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.ย  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
    • Is this not just about people wrecking, and storing, multiple cars in their front yard? I now a tow truck driver that was contracted by the council to clean up housing commission front and rear yards in houses and unit car parks I'm all for working on, and doing maintenance on your car in your garage or driveway, but some people definitely take the pissย  There's one house locally to me that I walk past regularly where the front yard and driveway looks like a wreckers, multiple cars in various stages of being stripped, and the yard looks like all of fluids are basically dumped on the ground I may be wrong, but it seems that the initial reports, which I've seen nothing actually official about yet, may be getting taken out of context, like alot of the latest "the sky is falling" stuff found on the youtubes for clicks
    • have they? Link appreciated. I live in Casey. I can see both sides of the argument in this case. There's a lot of sketchy stuff going on. There needs to be a clear definition of what this is supposed to be IMO. I wager the intent was to be a broad sweeping brush against people who have 4 cars up on blocks on their front lawn, not someone who services their own car behind their own gate on a weekend bothering probably nobody. But it'd be hard to legislate the difference there.
    • Oh, the wheels were already off. I wouldn't normally take them off to clean them although it does make it easier with the ceramic, so I might take them off when reapplying. I don't drive much but now with the ceramic coat, when I do drive and they get dirty I can get most off with the pressure washer. I'll be switching to dirtier pads soon which was the motivation for the ceramic as I usually just clean them and sometimes use Autoglym wheel protector. Nah, f**k the barrels! Haha, I'll give them a quick scrub when they're off the car and a pressure wash, but even I draw the line with the barrels. Yes, dark coloured wheels allow you to get away with a lot! ย
ร—
ร—
