Hey guys,
After installing my forward facing plenum on my r33 gtst the car is missing, backfiring and shaking struggling to stay alive.
Iv checked for vacuum leaks, bov seems to be working and fuel isn't old.
Could it be
My AAC valve air feed line from intercooler piping has a slight kink in it?
Afm,plugs,coil packs haven't been touched.
Injectors were taken out and flipped but I tried to handle them with care.
Has anyone had this happen to them?
Any of the injectors might not be firing if you have caused a connection issue on the loom plugs (or something similar).
A slight kink in the pipe to the AAC won't cause a problem, unless it has cracked or otherwise gotten damaged. As long as there is a bigger open area in the kinked part of the hose than the opening of the valve in the AAC it won't restrict flow noticeably.
Could pressure on the injector while it was out cause this?
A bending of one of the prongs that are on the tip of the injectors while they were on the bench do this?
    • Just buy a BMW if you want that... You can then choose whatever engine of theirs you want 😛
    • Clear vinyl wrap or clear coat?
    • There really needs to be an ODBII item that can play intake noise through speakers, synchronized with your current RPM and TPS%.
    • Worth most of the $50k alone!
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....😪 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will🤣🤑🤪🤣
