Hey guys,
After installing my forward facing plenum on my r33 gtst the car is missing, backfiring and shaking struggling to stay alive.
Iv checked for vacuum leaks, bov seems to be working and fuel isn't old.
Could it be
My AAC valve air feed line from intercooler piping has a slight kink in it?
Afm,plugs,coil packs haven't been touched.
Injectors were taken out and flipped but I tried to handle them with care.
Has anyone had this happen to them?
Any of the injectors might not be firing if you have caused a connection issue on the loom plugs (or something similar).
A slight kink in the pipe to the AAC won't cause a problem, unless it has cracked or otherwise gotten damaged. As long as there is a bigger open area in the kinked part of the hose than the opening of the valve in the AAC it won't restrict flow noticeably.
Could pressure on the injector while it was out cause this?
A bending of one of the prongs that are on the tip of the injectors while they were on the bench do this?
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
    • I just try to entirely stay away from ladder now unless it's something basic maintained by electricians. Even then and to your point, it mostly ends up being blocks I wrote in structured text.  PLC's are slowly going towards C, C++ and C#. I just wish Allen-Bradley would jump on the bandwagon.
    • All of them are missing. You do not get much done with just AND, OR and NOT unfortunately. Ecumaster for example has a text based editor with at least 60+ math and logic instructions.
