Hey guys,
After installing my forward facing plenum on my r33 gtst the car is missing, backfiring and shaking struggling to stay alive.
Iv checked for vacuum leaks, bov seems to be working and fuel isn't old.
Could it be
My AAC valve air feed line from intercooler piping has a slight kink in it?
Afm,plugs,coil packs haven't been touched.
Injectors were taken out and flipped but I tried to handle them with care.
Has anyone had this happen to them?
Any of the injectors might not be firing if you have caused a connection issue on the loom plugs (or something similar).
A slight kink in the pipe to the AAC won't cause a problem, unless it has cracked or otherwise gotten damaged. As long as there is a bigger open area in the kinked part of the hose than the opening of the valve in the AAC it won't restrict flow noticeably.
Could pressure on the injector while it was out cause this?
A bending of one of the prongs that are on the tip of the injectors while they were on the bench do this?
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
