Happy Laps - Queensland Raceway 27-10-13
Breakfast and laps, the supra guys decided they didn't want to be a part of this happy laps so I doubt we'll see any of them.
any reasons why they did not want partake in the event this time? Can PM me if more appropriate.
  • Replies 288
what is the total number of cars attending this event at the moment?
how many are needed? (30)
who else can we get along to fill slots that isn't a toolbox?
About 17 cars ATM Clint but I thig we will get a few extra show up on the day. We have to pay for 30 (incl passengers).
Back in for me and Kathryn
We will pay for her to be driving on the day of that is good
That mean she gonna fork out the money and become a finacial member? (Please note I'll hassle you both until she does) :)
    • Don't think that can fit in physically. Are you referring to this?    If it happens again, I'm going to get the nismo ones.
    • I bought the 1/18 scale celica and nsx from Justin and they are very detailed and good quality. I will definitely be interested in others in the series as they come out
    • Just install a grease nipple into the centre of the outer steel of the FUCA. Make sure the bushes aren't long enough to touch each other underneath that nipple. Cut a few mm off each if need be. Then you can push grease in there while it is all assembled. That was the very first thing I did (to all 4 ends) of the FUCAs on my 32 when I put Whiteline adjustable bushes into them. They would squeeze the grease out real fast, and I could squeeze it back in faster.
    • @GTSBoy I found the issue (sort of) when I took apart the bushing again, it was completely dry inside! When I experimented with it, all the grease would push out when I would compress the bushings. I wonder if this has anything to do with me putting in the poly bush first on both sides and then pushing in the metal barrel. Maybe I should have put in the metal barrel first then the rubber bushings so the spread pattern is different.   It's fixed (for now).
    • Just redid that entire job. 4 hours, but tightened everything properly. Had to jack the rotor instead of having the car on blocks as there was no room for the FUCA arms to tighten and the j arm. All good now. Cheers for the help!
