I was hoping that someone can help me.
I want to get some info on the re4ro3a auto (came standard in 300zx z32 & Nissan patrols)
The r33 rb25det auto is a re4ro1a. The 2 autos are the some ,but in the re4ro3a everything is bigger (so I've been told). The skyline bellhousing will bolt up & so on.
The person I spoke to about this auto said that, he can modify the valve body to 4gaers on the shifter, manual shift, & also a trans brake if I wanted
How many other mods is there for this auto ,is there any big pans for it
Has anyone pushed this auto to its limits, at what hp
Anything that anyone knows or heard about this auto, would be very helpful
Thank you for looking.
https://www.sau.com.au/forums/topic/431723-auto-mods-for-big-hp/
  • Replies 53
I've been looking on the Internet all morning, and I found a website that said ,
Re4ro1a was used for medium duty vehicles (r33 skyline, steaga)
Re4ro3a was used for heavy duty vehicles (300zx twin turbo, Nissan patrol gq-gu)
I also found the gear ratios for both (same ratios) ,& the 300zx had 3.692 diff gears ,which suits me
I would not be surprised if there are few to no physical differences between those two transmissions. There might be slight differences in the width or material spec of friction materials, or there might be line pressure differences designed to make it better able to haul around a heavier car.
Remember that in terms of manual transmissions, the big VG30 manuals are essentially the same gearbox as the big RB manuals. They're all about the same strength. It's trivial things that change, like overall gearing, the bellhousing, shifter location.
If you phone MV automatics in Adelaide they will help out.
Have you got a phone number / website
I also found out that they hold about 4litres, the guts of the auto is a bit wider & longer. The pump is also bigger
Folly built they can hold about 1000hp (so I've been told)
try 14 litres and your closer mate.
Let us know how you go with the auto
What you doing about the converter (standard , hi stall)
Will be around a 3500 stall. Mz will re work the std converter to what will suit your purpose included in that price
Auto was sent off today it will be back in 3 weeks to be installed and then some fun. Full manual valve body etc push button overdrive and push button lockup clutch for highway driv
So theres no automation on the lockup clutch at all? If you stop the car you stall?
    • So you're now accepting offers of 10% more than the cost of the turbo kit fitted?
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
