hey everyone, I have upgraded my stock turbo setup on my rb26 and now the stock water lines don't match up and I need to get custom lines made. My question is what is the best way to do this? On the 26 the water lines go from the front of the engine to the rear and the turbos are teed into that line, can I just run a line from the front split it into two and delete the rear return and just return all the water threw the turbo returns.
I like to keep things how they where designed but it will look messy and cost a fortune for all the fittings if I retain the top return pipe that doesn't look that important.
if use can not understand what I mean I will get a photo to help explain. thanks for your time
https://www.sau.com.au/forums/topic/431725-rb26-turbo-upgrade-water-lines-help/
you still need to run both the water lines front and back to a T and the other side to the block.
I tried running just the line from the back of the engine under the plenum and the block to my single but it didnt promote good coolant flow and made it difficult to bleed out air. I than added a T to the front on the upper water neck and it worked out much better.
What's this thermal syphon business?
Someone told me that when you turn the engine off the coolant keeps running through the turbos for a while but I was like yeah bullshit the waterpump doesn't magically keep spinning
Thermosyphon is actually a very easy to understand concept. In any fluid volume if you add heat to the fluid somewhere then its temperature will increase. Fluid at higher temperature is ALWAYS at a lower density than fluid at a colder temperature. Bouyancy forces then cause the hot fluid to rise. This is called free convection, and is a fundamental basis of how many things work. Things such as underfloor heating, the weather systems of planet Earth, etc etc.
If the fluid is in some sort of pipe (like the pipe running to and from a turbo's core) then the fluid will heat up in the core, rise, flowing out of the top outlet of the core. Because the fluid cannot leave a vacuum behind it, it will pull more fluid up the pipe into the bottom inlet of the core. This is the thermosyphon. This is a pumping effect run purely by heat transfer and bouyancy. And it works. Unless you get the surfaces so hot that the fluid boils, which can severely break the effect.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
