hey everyone, I have upgraded my stock turbo setup on my rb26 and now the stock water lines don't match up and I need to get custom lines made. My question is what is the best way to do this? On the 26 the water lines go from the front of the engine to the rear and the turbos are teed into that line, can I just run a line from the front split it into two and delete the rear return and just return all the water threw the turbo returns.
I like to keep things how they where designed but it will look messy and cost a fortune for all the fittings if I retain the top return pipe that doesn't look that important.
if use can not understand what I mean I will get a photo to help explain. thanks for your time
https://www.sau.com.au/forums/topic/431725-rb26-turbo-upgrade-water-lines-help/
you still need to run both the water lines front and back to a T and the other side to the block.
I tried running just the line from the back of the engine under the plenum and the block to my single but it didnt promote good coolant flow and made it difficult to bleed out air. I than added a T to the front on the upper water neck and it worked out much better.
What's this thermal syphon business?
Someone told me that when you turn the engine off the coolant keeps running through the turbos for a while but I was like yeah bullshit the waterpump doesn't magically keep spinning
Thermosyphon is actually a very easy to understand concept. In any fluid volume if you add heat to the fluid somewhere then its temperature will increase. Fluid at higher temperature is ALWAYS at a lower density than fluid at a colder temperature. Bouyancy forces then cause the hot fluid to rise. This is called free convection, and is a fundamental basis of how many things work. Things such as underfloor heating, the weather systems of planet Earth, etc etc.
If the fluid is in some sort of pipe (like the pipe running to and from a turbo's core) then the fluid will heat up in the core, rise, flowing out of the top outlet of the core. Because the fluid cannot leave a vacuum behind it, it will pull more fluid up the pipe into the bottom inlet of the core. This is the thermosyphon. This is a pumping effect run purely by heat transfer and bouyancy. And it works. Unless you get the surfaces so hot that the fluid boils, which can severely break the effect.
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
