Hey all,
I bought this for my S14 as I needed my seat to be lower than stock, unfortunately the seat was actually taller than the stock S14 seats. I can confirm I have sat this in a friends R32 and it is roughly the same as stock. The S14 seats were simply much lower.
The seat is a GOOD quality and near new Recaro SR3 replica with Recaro Gradation fabric.
The rail is a GENUINE Bride Low Max rail for R34 but will fit all skylines and can also fit silvias with some modification.
Both of these are near new and in VGC.
Price is $400 ono
Thanks,
May be interested in swaps for some parts such as:
- S15 or GTR torsen LSD and 5 bolt half shafts
- OS Giken TS2B clutch parts (need good condition plates or rebuild kit) doesn't matter what model this is made for, the plates and bits are all the same
- New rotors for R33 GTST
- Quality branded radiator suit Silvia
Cash adjustment where necessary.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
