Hi all,
I need a new HD clutch soon and have noticed that the Exedy ones are about $150-200 more then the RPM equivalent.
Is it worth it to spend the extra on the Exedy or is there really no difference?
I basically just need a clutch that can handle up to 230rwkw so hoping that either HD will be ok.
Thanks.
DO NOT get the Exedy Heavy Duty Range, the pink pressure plates, they're rubbish.. make sure it's the silver cover which is made in Japan.. not a remanufactured OEM item that is sprayed pink.
I bought my car with an RPM clutch and it was slipping hard (due to uneven wear) so I removed the clutch kit and replaced it (my only experience).
I've got an excedy heavy duty, I don't know which model but when I did the engine swap and moved the clutch over it was about 75% worn (hard to tell) and the pressure plate is pink. I just tuned up to 240rwkw and it doesn't just bite any more theres a split second of slip. 3rd gear won't stall the motor any more, if I let it out in 3rd on boost it will just slip.
Is my clutch on the way out? I'm going for 300rwkw at the end of this year, not sure whether to do it first. Lots of people say over 300 is fine with this clutch but i'm not convinced
Blackkers, chuck it into 4th gear and boost up a hill. You will either notice it slip or it won't slip and that's how I would determine.
My pink excedy lasted a few power runs on the dyno before giving up on the way home on the highway. This was 250rwkw
I am currently running a KB clutch from KB clutches in Sydney. Great service and amazing price, just call him and send him a dyno sheet or some specs of the car and he will do the rest
Okay mate I'll definitely give it a go. I know the clutch has a bit of meat on it i'm just not sure how it will handle the power i'm chasing. Thanks for your input
KB seems to be the place for clutches too
Edited by Blackkers
Got the RPM in the end, haven't fitted it yet but it looks pretty decent.
Honestly couldn't justify spending almost double on an exedy.
Good luck mate, hope they have revised their clutches. They had a bad run for a while, and I was one to suffer from it.
It depends on where u buy the clutch from i guess
i bought a new hd exedy clutch and gtr racing flywheel for 925 shipped to my door and it only took one day.
call this number and ask for simon and tell him josh from armidale gave u his number 0296481688
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
    • Nah. H2S. H2S is "rotten egg gas", which is what is associated with no cat. SO2 is equally nasty, and if you've ever smelt it you'll know all about it. More of a choking, acid in the back of the throat sort of thing. But you can only smell it in a narrow range up to about 1ppm. Above that, it irritates your mucous membranes, but you don't smell it.
    • Kicked the 34 in the guts, she won’t be seeing the road till I get the 31 mobile again.  wont be long and she’s a bit of a garage princess anyway haha
