Hello everyone, I thought I would share, I had my cambelt done today at the garage they decided not to replace the water pump as it appears to be okay. So they got it all done and took for a test drive and the water pump snapped where it connects to the fan. Ruined radiator fan and trans cooler.
Lesson learned today.. Always replace water pump lolpost-119800-0-03946500-1379052903_thumb.jpg
https://www.sau.com.au/forums/topic/431786-rb25de-waterpump-blew-to-bits/
Wow! That's the first time I've seen that. I would be hesitant to go back there. It's really worth replacing the water pump, idler, Tensioner and cam seals when it is all apart, especially when you are paying someone else to do it.
The waterpump is driven by the fanbelt not the cambelt and before i took it in the fan belt was pretty tight, I think that maybe they didnt install it correctly after inspecting it and it got jammed i dont know how else it could break there.
They are going to replace the broken parts (hope they dont charge me for it) I will see how it turns out when i pick up on monday
Wow that would've sounded horrible when it went. Definately getting a pump change when the timing belt is replaced. :O
I recently did my ancillary belts and even though my fan belt was tight, I had to tighten it again to stop squealing.
Kinda makes you wonder just how tight is overtight.
I had a substantial piece of the water pump snap off underneath the shaft. I was freaked out too.
Timing belt was replaced months ago.
So yeah, I believe it. Looked like the casting had a hairline crack.
But you have to take off all the ancillary belts to do the timing belt ;)
Or possible the shop used a breaker bar and cranked the car to crack the nut but screwed up and cracked the water pump.
Slight chance?
Big chance! Even if the water pump was a cheap n nasty casting it didnt "blew to bits"!
Its had a lot of force put on it and its been broken
Edited by StevenCJR31
I would never do that - just put the car in gear and use some of the man power to torque it out - cranking the car is so bloody dangerous i reckon!
I always crack the nut by cranking it over. It only takes a split second to do it, just make sure the brake bar is suitable. My car is an auto so the put it in gear thing won't work.
Why are they cutting corners? Sounds like a shit shop who doesn't care. They also caused this. I changed my water pump when I did my belt not because it needed to but more the might as well factor.
Also I never needed to crank to crack the nut. Big breaker bar to take it off and properly torqued on. I'd also bet they used a rattle gun or just guestimated the torque when putting the nut on the crank.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
