Hey. Just a few questions, I think its about time to do a service on my 33. It's the first service it will have had since ive owned it and so I just want to ask about what oils you guys swear by and what plugs would be best to use in a stock 93 GTST. Im planing on changing the engine oil, gearbox oil, coolant and brake fluid.If ive left anything out let me know :) I'm not the best at mechanical things but between me and a mechanic friend and little help from you guys i'm sure I can muddle through it
And yes I know theres a maintenance section but I just want to hear what some other victorians have got to add to it all :P
https://www.sau.com.au/forums/topic/43182-service-time/
i use:
oil: penrite HPR10 (10w50)
coolant: anyhting thats anti-freeze/anti-boil and at 50:50 ratio with water
plugs: NGK coppers BCPR6ES (coppers are fine at $3 each and change them every 10,000kms or so)
i agree with all that except oil, i use OWS or Castrol 10w-60
than again a 33 and 32 are much different age-wise, would the japs have used synthetic oils on 32s ? as its REAL bad i heard to use synthetic in an engine that has previously used non-sythetic
https://www.sau.com.au/forums/topic/43182-service-time/#findComment-882021
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
