Two Item And A Button In My Car - What Are They?
Hey all!
Just wondering if anyone can tell me what this button is? It's just on the bottom left of the steering column... it only presses, it doesn't switch...
Also, I have this strange little unit in the right hand corner my dash... does anybody know what it is??
Cheers!!
Lego
Ok, I have some better pictures.. Any ideas?
On the unit on top of the dash, the switch on the side has three settings - off - 1L or IL - SQ.
It definitely looks like a little solar panel and has what looks to be like four LED's on the front of it.
Cheers!
Not sure about the dash solar thing, but why not undo the 3 screws that hold the lower dash on and follow the wires from that switch. I'd be interested to know what it does.
I'm guessing that if it's anything stock then the wires will very quickly disappear into the web of wires under the dash.
Mate of mine had a similar button. couldn't work it out for ages. When we took off his front bar we found an old radar detector/scrambler black box. Traced back the wiring and it went to a module that the switch was wired to.
the button that just presses is for the parking light on a stick that comes out of the passenger front side on the bumper. had one on my 33. its prob been taken off but the button remains.
That sounds pretty unique, never heard of/seen one of those. Got pics of the actual unit?
    • You guys need to live a little! Nothing keeps the blood flowing like lying under something that could collapse on you at any time! The vast majority of the weight of my car is out of it. There's zero attached outside of the interior of the car. It's pretty much full interior but once I take the front seats out it's just the dash and some of the boot contents remaining. I would guess that as it sits it would be already well under a tonne, even less without the seats.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
