Two Item And A Button In My Car - What Are They?
Hey all!
Just wondering if anyone can tell me what this button is? It's just on the bottom left of the steering column... it only presses, it doesn't switch...
Also, I have this strange little unit in the right hand corner my dash... does anybody know what it is??
Cheers!!
Lego
Ok, I have some better pictures.. Any ideas?
On the unit on top of the dash, the switch on the side has three settings - off - 1L or IL - SQ.
It definitely looks like a little solar panel and has what looks to be like four LED's on the front of it.
Cheers!
Not sure about the dash solar thing, but why not undo the 3 screws that hold the lower dash on and follow the wires from that switch. I'd be interested to know what it does.
I'm guessing that if it's anything stock then the wires will very quickly disappear into the web of wires under the dash.
Mate of mine had a similar button. couldn't work it out for ages. When we took off his front bar we found an old radar detector/scrambler black box. Traced back the wiring and it went to a module that the switch was wired to.
the button that just presses is for the parking light on a stick that comes out of the passenger front side on the bumper. had one on my 33. its prob been taken off but the button remains.
That sounds pretty unique, never heard of/seen one of those. Got pics of the actual unit?
    • Nope, but they are definitely one of the default choices. Well established.
    • Has anyone used > https://performancecoating.com.au/
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
