Hey guys,
I know I am pushing it but does anyone know of a computer store open on a Sunday.
MSY is closed and so is Gemini tech
My dad is heading back down the coast on Monday and I need to get his hard drive replaced on his computer.
Also willing to buy a 500-1TB internal hard drive if someone has one spare
https://www.sau.com.au/forums/topic/431833-computer-store-open-on-a-sunday/
I've got a m8 who might be selling HDD's. I'll give him a buzz.
edit: if you don't mind second hand
editx2: No luck - he sold em.
Edited by RosieR34
Oh also external HDDs have standard hard drives in them. If you get desperate buy an external and crack it open. I've done it multiple times. But that PC store in tuggers 100% will be open I'd say
Hopefully they are open.
I'll go check it out tomorrow.
Unfortunately it means I will miss the cruise but I have to get this sorted ASAP before he heads back down the coast.
Worse comes to worse then I will just buy an external and rip the cover off, if Anthony can confirm that it will plug in normally
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
