Car was recovered this morning. No bike in it. still dont know what else is gone, has some damage to a front panel and rear wheel.
I should get more info tomoz. Was found in lang warren.
No CCTV in close proximity. doubt they would have gone straight to a servo when i had 1/2 a tank.
regards, brendan
Think it might be a write off, damaged front left guard (front left door fowls quater panel when opening door" and front left wheel is about 30cm towards back of car with severe gutter rash on 1/2 wheel, and left rear wheel has + 45 camber and gutter rash on 1/2 wheel. Chunks of rubber missing on tyres with 90% tread.
I can only Imagine the burnouts and dougnuts they tried in an rs4 and ended up in gutters.
  • 5 months later...
Maaaannn that sucks the big one.
Did you get it back on the road, or was it written off ?
Mine went missing last night, virtually Identical spec RS4 with Towbar and "The USA Surf" Japlish sticker.
Preston / Coburg area. Grrrr.. . .
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
