Hey guys does anyone know whether mounting gauges in the dash in front of passenger is legal or not I have searched everywhere and nothing explains it. There is lots about on the dash and side pillar but not in the dash itself? Help please!!!!!
https://www.sau.com.au/forums/topic/431851-gauges-mounted-in-dash-illegal/
As far as I know they are only illegal if obscures your few out the window and I do believe not allowed to be above dash line. Mines mounted on pillar and is spot on in line with the highest point of the dash around dash cluster.
I have mounted 4 apexi ones in the dash where some cars have front passenger airbag. My concern is a cop will tell me that its illegal because the passenger could hit them in a crash but I can't find any info
Thats a tricky one to work around I think cause as you said thats more then likely what they'll go you on.
Pretty keen to know the exact rules on these as well. I know the guage pillar that sits above dash is definitely illegal in QLD.
But whether the 3 gauge pod that sits on top, I'm not sure but have seen a lot of other cars with these.
When I bought my 32 gtst my boost gauge was in the glovebox haha...
Edited by ZRBE
Mechanical gauges inside the car are a no no. Electric gauges only (unless something has changed).
Mounting - can't obscure vision, can't be more forward than the front most part of your dash (hence no A-Pillar placement unless factory like the JDM S15)
The new ADR's are a pain in the ass, trying to find the exact ones for you.
  • Like 1
Cops don't seem to have a worry about where mine is on pillar down at most furthurest point so doesn't obsure window at all. In saying so it is blocking the demisted for driver window.
Okay, great.
So, ie. boost guage with vacuum line (mechanical?) - Illegal.
Oil temp (electric?) Legal?
Sorry.
  • Like 1
Okay, great.
Sorry.
That's what I've heard as well. Apparently in a crash hot oil can potentially make it's way into the cabin via the hose and be a hazard?
Never herd of that.. But my car is going to be so overkill when it comes to heat wrap & the material I use for all my engine bay hoses lol
Well then that'd make my boost gauge illeagal seeing as it has a air tube going from back of gauge to the engine bay. Would it? I mean it's only a air tube right? No fluids?
It's just a vac line off the manifold so no fluids.
Downloaded this PDF from QLD Transport a while back.
Thank you Jiffo. Printed.. so its a field of vision thing. I would be willing to take that to court. If I attach my GPS Unit that is way worse than A-Piller gauges...
  • Like 1
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
