This was my first GTR35 set which I completed for a local car. I ended up attempting the True Quad setup and I was pretty happy with the way they turned out. I learnt quite a lot from this first set. Ill know what to do and what not to do for future sets.
Enjoy the pix....
HL specs:
* JDM GTR35 headlights
* Quad Mini H1 5.0's
* White painted cutoff shields
* TRS side emitting LED strips for the new "Parker" setup
* Mini Gatling Gun shroud (Low beam housing) + regular Gatling Gun shroud (High beam housing)
* Full Satin Black finish using: VHT Prime coat SP305 "Satin Black"
CLear lense pulled off
OEM low beam projector vs Mini H1 5.0.
Both lense holders are lined up. Very similar sized projectors
2.5" Mini H1 lense vs Slightly smaller OEM lense (forgot to get a measurement)
Mini H1 fits like a glove in the OEM low beam reflector bowl
Even the OEM headlight bezel fits around the Mini H1 without any modification. Looks just like factory :) Happy days!!!
Anyone that wants to do a projector upgrade on a GTR35 HL will have the least hassle free experience with a Mini H1.
* minor dremelling of the housing underneath the projector
* JB Weld / Stik Mini H1 to the OEM reflector bowl
* Fit OEM bezel (without modifiaction)
Done deal!!
Bottom section of the OEM projector still needs dremelling
This is the dremelling I was talking about to fit the Mini H1. This helped with rotational alignment.
Close up
Both projectors fixed in place using JB Stik. You can see the M4 nuts & bolts thats helping to extend the Mini H1 in the High beam housing
Side emitting LEDs installed and showing off the new "Parkers"
Heres a mock up of how I want the Gatling Gun shrouds to look
The first initial cut on the Mini GG. I was still afraid to hack into the OEM low beam bezel incase I couldnt pull off the look. Once you cut into it theres no turning back...
Sliding the Mini GG inplace... Still requires a lot more cutting..
Finally bit the bullet!!! Had no choice as the Mini GG shroud was not going to "slip" in any further without cutting the OEM bezel
More cutting leading to a better fit
Getting closer and closer
The final look of the OEM low beam bezel. No more cutting
Mini GG trimmed to a final depth of 45mm for the best fit
Test fit
The first initial cut of the OEM high beam bezel
Test fit of both Gatling Gun shrouds with electrical tape holding them in place
Gardening wire hold the Gatling Gun shroud to the OEM headlight bezel
JB Stik applied as the primary adhesion
JB Stik finally cured and hold the shrouds in place
Dressed in Black
Turn signal housing masked up before the Satin black finish
Assembly line
All that left to do is seal the HL up
Testing the LED strips
H1 bulb now protrudes from the back of the high beam housing. The dust cap no longer fits.
Giving my plastic welder the vital info he needs: ">PP
That looks amazing :woot: Seems like very fiddly work with a lot of thought put into what to cut/what not to, but in the end looks like a concept R35 headlight, just 100x tougher. Awesome!
Edited by colourclassic
