Hi guys,
Up for sale is my 1996 S2 R33 GTS-T, very well looked after. The car has 157xxx km's on it and has been serviced by me around 3k ago. Has rego till 15/11/2013.
List of fluids I use on the car:
Mutul 8100 X-cess
Red Line MTL gearbox oil
Royal Purple diff oil
K&N oil filter
The car has the following modifications by the previous owner:
Lowered suspension
17" Advan Tri-spokes (front 235/45 falken, rear 255/40 toyo proxes t1 sport)
GTR wing
Front strut brace
CRD FMIC kit
K$N pod with enclosure
Full 3 inch Fujitsubo turbo back exhaust
Walbro fuel pump
Turbo Smart manual boost controller with a flick switch in the cabin between 7 and 10 PSI
Car was tuned by Toshi to 186rwkw (stock ECU remapped)
Autowatch Premium alarm system
JVC touch screen DVD player
Boston split system speaker front
Clarion speaker rear
Kenwood amplifier and subwoofer
Skyline genuine mat sets
Interior are good, all the seats are perfect condition. Exterior is not perfect, bit of clearcoat faded on the roof. There are few stone chip, small dings and scratches. The original paint is still very good.
Reason for sale is that I just bought a house and thing getting difficult and I have a bike to travel to and from work. Very regretful sell.
Price is $9,000 ONO. Located at Chester Hill NSW. SMS on 0403 201 566.
https://www.sau.com.au/forums/topic/431880-nsw-1996-s2-r33-gtst/
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
