its a new pump.the old and the new one wouldn't have the same problems .different housing ect ..yes the pick up inspected and clean. and oil drain bk mods at only 225hp if that much would mean this motor has serious issues if its needed .
If you ignore blowby, HP figures are totally unrelated to oil pressure and flow. You could have a 50HP RB26DETT with oil drain back issues. Just say'n, don't rule anything out due to hp figures.
Jeff
If you haven't had a good run with your engine you may not know if you are going to have oil control problems - and they are not related to hp but to revs and oil pump choice. there are two main symptoms - at extended periods at WOT such as on the straight on a track or on a dyno you can get too much oil in the cam covers so that it spews out everywhere. The other is that you can pump the oil out of your sump faster than it flows back potentially creating oil starvation. If you have the head off I would bang the appropriate restrictors in now anyway.
yes I understand how the oil system works ..this build has zero blow by ..and as for rev ..its prob seen 5000k to redline 5x in its 400miles... when my pressure drop off its usually from a 2nd gear pull. not going tru the gears and shifting hard .. I simply accelerate from 2k and by 3k my oil is up to 60psi.by 4 stays around 65 and by 5k falls off to about 55psi and would stay there to redline if I hold it.
  • 1 month later...
UPDATE!!!!!!
so guys i have changed the bearings and went a thou thicker ..so clearances by elimination now is about .0016-.0018 and the oil pressure is up like a bitc* ..at start up its bk to 78psi but at a blip of the throttle of around 2500k its up to 100psi n climbing ...when warm it idles at 28-30psi when heated after some pulls it rests about 22-24psi ...at 3k when hot or warm its up to 70 psi at 5k its up 84psi .... when hot after some pulls it goes around 60psi at 3k and 74-78psi at 5k and holds..i havent hit the limiter yet as i see no reason too ,, car pulls hard...
have a new problem now..lol... experiencing windage ... my rb26 is in a s15 so we used a rb25 sump ..and did a lil customising to the sump...first i had 4.5l of 20-50 oil in it and when the boost hit over 16psi the oil pressure would drop to around 35psi when it climb rpm fast ...i added 1.5l for a total of 6l and now when i boost it drops off from 82 to 70psi on pulls ...so am assuming its time to get a 7L sump to help combat the problem..
but even how its set up now am still satisfied as am only revving 6k and getting 70 plus psi will over the 10psi per 1000rpm rule...
and yes the bearings had damages to them from the break in period of just 600-800km on low to no boost ....
also my tach was off so it was more like getting 3.5bars at 4200 rpm with the wider clearance and staying there...
hope this info is help full to other builders
so rule is...... wide clearance require bigger pump or oil pressure will be on the sad side......
Edited by crashsvg
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
