Morning fellas,
As the titles states I seem to be having a major issue with the A/C in my ECR33. It seems to be leaking refrigerant in the passenger footwell and as its evaporating (through the vents for the demister), fogging up on the windscreen as it goes. There's no overheating problems with the engine at all, as temps are normal throughout.
2EF7EBC5-118A-4446-B529-A25DFC817703-212
C9CEFC9A-18EA-470C-AB3B-0EA54DE6B72A-212
^Where the leak in the cabin is occurring.
Now basically this needs to be fixed ASAP, but will the leak/evaporation continue to occur if the car is driven without the cooling system used at all, and has anyone ever had a similar issue at all?
https://www.sau.com.au/forums/topic/431888-r33-ac-problem/
is there any refrigerant left?
If this is the case, disable the A/C immediatly or you may destroy the compressor if you turn it on.
Are you sure that its the refrigerant causing the window to fog up? Or just because there is no A/C action to demist the window?
https://www.sau.com.au/forums/topic/431888-r33-ac-problem/#findComment-7020810
ac systems have a pressure sensor, so if there is no gas in the system it won't engage the compressor and damage it. Are you sure it's refrigerant, it might just be condensation due to the drain being blocked. The refrigerant is a gas that dissipates, the lube oil is what would drip out, so is that liquid oily or watery?
https://www.sau.com.au/forums/topic/431888-r33-ac-problem/#findComment-7020875
That could definitely be the heater core. I had the same in one of my cars. Wet passenger footwell and foggy windows.
Get a white paper towel and press it onto the wet area. Check its colour. Smell it and feel it. You'll know if its coolant if it is. It could be your ac drain but I doubt you've used your ac enough for that.
Edited by SargeRX8
https://www.sau.com.au/forums/topic/431888-r33-ac-problem/#findComment-7020969
Thanks for the replies fellas. Okay I could be wrong, but the window definitely isn't just fogging up because of the A/C demister not working, the fluid leaking is 100% causing the fog up. Also ill double check coolant levels when I get home, but the smell coming into te cabin has a very distinct collant sorta smell too it.
https://www.sau.com.au/forums/topic/431888-r33-ac-problem/#findComment-7021256
Coolant smells really strange, you just know its coolant. It also feels oily to touch. There are two methods to fix, the hard method is to replace the heater core. The easy method is to bypass heater core then use an air compressor into the core to shoot the rest of the water out.
Also to clean up the coolant do what I do, go to the local 24hr carwash and throw two bucks into the vacuum machine.
https://www.sau.com.au/forums/topic/431888-r33-ac-problem/#findComment-7021577
There is a "how to" in this site on changing the heater core without pulling the dash out (via the glovebox etc). Due to try it myself shortly.
Cheers mate ill be sure to check it out, that's the main thing that had been putting me off replacing the core itself. The sheer effort of the dash removal lol.
Edited by gtsttrk
https://www.sau.com.au/forums/topic/431888-r33-ac-problem/#findComment-7027454
Here ya go:
http://www.skylinesaustralia.com/forums/topic/280174-removal-replacement-of-heater-core-skyline-the-right-way-without-removing-the-dash-at-all/
https://www.sau.com.au/forums/topic/431888-r33-ac-problem/#findComment-7027701
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
