Currently getting the datsun tuned with a vipec plug in and am having a strange issue wit the computer disconnecting at 5500rpm and full throttle. Any thoughts from the brains trust?
Setup is rb28, 272 9.85 camshafts, 2200cc bosch injectors, plugin Vi-pec, 6466 turbo.
https://www.sau.com.au/forums/topic/431953-vi-pec-disconnect-issue/
yeah i get this sometimes....
electrical interference and usb does NOT mix. and there is nothing you can do about it.
i had to tune a 850hp supra offline because of this, the way i did it was setup offline logging and after the run i would download the log and adjust then save then repeat...
I had no other choice as i only had an hour to tune that car, but there is another option... if you use the serial cable then it should usually fix the issues, i have one that i made a few years ago but it was in my skyline and not available to me at the time.
you can call your vipec dealer and they can order the serial cable for you, then you need a laptop with a 9pin serial port not a usb to serial converted.
ps: i hate usb. serial all the way.
*good news everyone* (dr farnsworth voice)
because i am such a nice guy and not so lazy (not) I decided to do a search and i found a old email from back in 2009 from Ray Hall with the details you need to make your own serial cable.
you gotta change the cable to the CAN port on the board if using a plug in, if using the v44 or v88 you just put the cable on the can port.
good luck
GT
Shielded the spark loom and changed to a different plug. Seems to have fixed the issue of ecu disconnect but we now have a slight missfire at 6000 rpm that sounds subtle. Car is officially giving me the poos.
    • @Dose Pipe Sutututu I would argue that >300rwkW inevitably comes only with a raised boost threshold that makes it more likely to get beaten by the family SUV with a 95 speed auto transmission and TD torque. Ditto the traction problems when it finally does come on boost. I used to love my stock turbo. A little flex of the ankle and it made a sweet little whistle and you had torque immediately. It wasn't fast fast, but it was more likely to win the "squirt to make the gap" type races that actually matter for a street car. I think >300 rwkW requires more capacity than an RB25 can offer (again, for street driving). I have enough experience with driving 2JZs in that space to know that they are much easier to pedal around in than a 25. I keep thinking Greg did the right thing putting a V8 is his car. I can't see myself not having a turbo - but I'd really like a big engine torque curve.
    • This is kinda how I see it also. Could drill down then into sub tags.
    • Let's be honest here @GTSBoy 250kW in a GTS-t would easily get walked by my a family SUV these days. 300kW is the sweet spot, fast enough to keep up with the modern German cars (not from a stand still), fun enough and the motor still can be stock/unopened. Realistically, 400kW is a good number. It's enough to give you cold sweats, still be very street able in terms of the power band (provided you're not an idiot and go single scroll and delete VCT) and only needs a very basic rebuild (or stock if you have a NEO motor). Anything more, it starts to be stupid.
    • Deals off now apparently https://www.abc.net.au/news/2025-02-13/honda-and-nissan-say-merger-talks-called-off/104934438 Hopefully Nissan closes up soon and the family X-Trail becomes a classic too!
    • The west where I live is swarming with birds, not wrong they are bloody loud. In the meantime, do a DIY killswitch - $5 worth of things from jaycar, easy as too. The west is copping it with car theft lately, especially the big shopping centres.
