Clean R34 Gtt For Sale!
sirjb
 Share
1998 R34 GT-T Skyline
152 xxx
The km on this veh are mostly highway km, it has been extremely reliable, regularly serviced and has never seen a race track.
There is some wear on the steering wheel, but the rest of the interior is in good condition.
The car is making 260Kw on a safe tune! This car has the hardware to make ~300kw.
Driveline
RB25DET
Exeedy HD Cushion Button Clutch
Stock gearbox - no synchro issues
Nismo 2 way diff
Brakes
Front – Slotted and cross drilled vented rotors with DBA Pads
Rear - stock rotors with DBA Pads
Rolling stock
Front
Rota Grid Drift 18"x 9.5
Federal 595SS 255/35/18
Rear
Rota Grid Drift 18"x 10.5"
Archillies 235/45/18
Fuel
Walbro 255lbs in tank fuel pump
Bosch Ev14 injectors
Nistune v3
NGK Iridium Spark plugs.
Intake
ATR43G3 Turbo
Z32 AFM
2&1/2” Intercooler piping
Blitz Sequential BoV (Stock BoV also incl)
Exhaust
3" JustJap Dump and front pipe
3" Red Back High flow race cat
3" Magna flow exhaust to 2" twin tips
Cooling
ISC Performance Intercooler
Stock radiator
ICE
Blitz Sequential Boost Controller ID
Blitz Turbo timer
Defi BF guages boost, oil pres, oil temp, water temp with controller
Linux based head unit - Tv, DVD, cd, iPod, mp3 - there isn't much this doesn't do.
Pioneer 1000w subwoofer
Kicker 300w RMS Amp
Front speakers- Pioneer 200w 6" Speakers
Rear speakers- JL Audio 225W 6" Speakers
Custom carbon fibre dash cluster with green LED
Suspension
Pedders X2 fully adjustable coilovers - these are excellent!
Aftermarket Side skirts
$21,000
Edited by sirjb
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
