So ive been searching around for awhile in topics related to ABS units on r32 gtr's as mine has started to leak. Found a few threads on people deleting them completely etc but i plan to just replace mine with a newer unit that i recently picked up. Couldnt find any guides with pics on people deleting/removing their abs units so ill have to figure that out myself when i install my new brake pads, rotors and replace the fluid.
My dilemma is, ive always been told not to run the BMC dry, ok fair enough ive looked that up and seen how much pita for some to get it back working 100% again, but removing the ABS unit and putting the new replacement in will obviously end up having some air get into the system once i reconnect everything and clean up the mess and ive seen few mention that getting air into the abs unit itself is also a problem and a half to fix and get the air out.
So my question is, if anyone has replaced their ABS unit before, did you run into problems bleeding the system after and getting air out of the unit? or was it simply replace unit then bleed system and all fine and dandy again?
Cheers,
Dee
I did mine. Was a PITA to get it fully bled again, but quite possible. Just kept bleeding until i had a hard pedal. I used a vacuum bleeder on the ABS itself - not sure if that's necessary tho.
How many bottles of brake fluid did you end up using and how did u use the vacuum bleeder on the abs itself? Haven't used any of those bleeder tools before usually just normal gravity bleed but in this case I need to make sure as I'm changing rotors and pads at the same time wud be embarrassing taking it out to bled in brakes and neck minut cant stop haha
Cant remember how much fluid i used but i always have a couple of 500ml bottles on hand. I also usually just gravity bleed but due to the ABS nipple location I got the vacuum bleeder. You just put the hose on the nipple, release it a bit and pump away.
I would do the pads and rotors before or after, just to separate the work to simplify it.
Also you shouldn't ever get in the situation where you cant stop - dont take it out until the pedal feels right ;)
haha well was over exaggerating with the cant stop situation, wudnt risk my car like that =P and cheers, i only recently found out about the abs unit having bleed nipples so im assuming as its located on the top, gravity bleeding it prob wont work? ill buy a vacuum bleeder if thats the case. Probably also get 4-5 bottles just incase and do the pads and rotors after the unit is bledded in and entire system flushed.
Thanks for all the help =)
    • Yeah, all the crude is used for fuels and petrochem feedstocks (pesticides, many other chemicals, etc etc). But increasingly over the last few decades, much of the petrochem synthessis has started with methane because NG has been cheaper than oil, cleaner and easier and more consistent to work with, etc etc etc. So it's really had to say what the fraction either way is. Suffice to say - the direct fuels fraction is not insigificant. Heavy transport uses excruciatingly large amounts. Diesel is wasted in jet heaters in North American garages and workshops, thrown down drill holes in quarries, pissed all over the wall to provide electricity to certain outback communities, etc etc. Obviously road transport, and our pet project, recreational consumption camouflaged as road transport, is a smaller fraction of the total liquid HC consumption again. If you're talking aboust Aussie cars' contribution to the absolute total CO2 production of the country, then of course our share of the cubic mile of coal that is used for power generation, metallurgy, etc adds up to a big chunk. Then there is the consumption of timber. Did you know that the production of silicon metal, for example, is done in Australia by using hardwood? And f**king lots and lots and lots of hardwood at that. Until recently, it was f**king jarrah! There are many such sneaky contributors to CO2 production in industry and farming. NG is used in massive quantities in Australia, for power gen, for running huge water pumps (like, 1-2MW sized caterpillar V16 engines running flat out pumping water) for places like mine sites and minerals/metals refineries. And there are just a huge number of those sort of things going on quietly in the background. So NG use is a big fraction of total CO2 production here. I mean, shit, I personally design burners that are used in furnaces here in Oz that use multiple MW of gas all day every day. The largest such that I've done (not here in Oz) was rated to 150MW. One. Single. Gas burner. In a cement clinker kiln. There are thousands of such things out there in the world. There are double digits of them just here in Oz. (OK< just barely double digits now that a lot of them have shut - and they are all <100MW). But it's all the same to me. People in the car world (like this forum's users) would like to think that you only have to create an industrial capability to replace the fuel that they will be using in 10 years time, and imagine that everyone else will be driving EVs. And while the latter part of that is largely true, the liquid HC fuel industry as a whole is so much more massive than the bit used for cars, that there will be no commercial pressure to produce "renewable" "synthetic" fuels just for cars, when 100x that much would still be being burnt straight from the well. You have to replace it all, or you're not doing what is required. And then you get back to my massive numbers. People don't handle massive numbers at all well. Once you get past about 7 or 8 zeros, it becomes meaningless for most people.
    • @GTSBoy out of the cubic mile of crude oil we burn each year, I wonder how much of that is actually used for providing petrol and diesel.   From memory the figure for cars in Australia, is that they only add up to about 2 to 3% of our CO2 production. Which means something else here is burning a shit tonne of stuff to make CO2, and we're not really straight up burning oil everywhere, so our CO2 production is coming from elsewhere too.   Also we should totally just run thermal energy from deep in the ground. That way we can start to cool the inside of the planet and reverse global warming (PS, this last paragraph is a total piss take)
    • As somebody who works in the energy sector and lives in a subzero climate, i'm convinced EV's will never be the bulk of our transport.  EV battery and vehicle companies over here have been going bankrupt on a weekly basis the last year.
    • With all the rust on those R32s, how can it even support all the extra weight requirements. Probably end up handling as well as a 1990s Ford Falcon Taxi.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
