For sale 1998 Nissan skyline R34 GT-T RARE factory 4door 5speed manual!!!
The car is pretty much stock standard
Only mods are:
GTR HID headlights with tilt control
Driftz Boost tap
HKS bov
Blitz gauges in dash
Aftermarket short shifter
Nardi shift nob
Blue LED in cluster
17" SSR wheels with new tyres
2" lowered Compressed springs
JVC headunit and MTX audio speakers with splits
Plenty Rego till next year 17/7/2014
Car is always serviced every 5000kms with Penrite oil.
Always washed and cleaned on the weekends.
Bad points:
some idiot hit and run reversing onto the bonnet just last week leaving a dent on bonnet. Car parks for you!!
Roof clear is starting to peel a little.
Rear bar was painted by can so not exactly the same as the body. But still not bad for a can spray.
Also have full URAS kit to go with the car that was originally on the car before but I didn't like it so i bought stock bumpers and put them on for my liking.
Price 10k firm!!
Contact on 0401730850 for more details
Photos are on my phone so txt me and I'll send them through.
    • Not sure if you're being serious? I, and all the car people i know, ALWAYS use a torque wrench for wheel nuts. I assumed any car person, apart from tyre centre monkeys with rattle gun in hand, would do it properly.  Anyway, no further reply from me on this unless legit discussion from OP or his query so, over to you, knock yerself out.
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
