Hmmm,
OK, here's the deal. We've been playing around with making a shift light kit. Simple freq to volt converter and a comparator.
Had it all hooked up to the car and it wasn't working, so we decided to change a capacitor. Stupid me changed it while it was still hooked up.
Now my tacho doesn't work and the ABS light just stays on (the ABS isn't working - I tested that !!). I MAY have shorted the tacho ECU output to ground or 12v+ for a split second.
We hooked a signal generator up to the tacho on the dash and it swung around, so that's working. It looks like there's no signal coming out of the ECU for the tacho :P;)
Has anyone else had this???? The strange thing is that the ABS light stays on now !!!
I've checked all the fuses and they (dash, boot, bonnet) are fine. Did the diag's on the ECU and it came up with 55 - all is OK.
Does anyone know where the ABS fuse is??? It's all in Jap.
If it is just the ECU it's not too bad cause I'm getting a new ECU in a week or two, but the ABS thing has got me worried.
Help me Obi Wan Kanobi - your my only hope.........
J :):(
dunno if this helps but when my battery recently went flat I jump started it and since then my air bag light would not turn off.
took it to nissan and they said it happens often when you jump start and they simply reset it in a couple if minutes by hooking it up to their computer. (but charged me $80 the bastards)
Thanks Guys,
I'm getting a re-mapped ECU in the next week or two, so once that get's plugged in I'm hoping that everything will come back to normal.
I think what I've done is shorted the tacho output of the ECU to ground for a split second, and I think this has popped one of the chips in the ECU. And I 'think' that chip also has an output to the ABS.
If the new ECU doesn't fix the problem I'll have a good search through the car and see if I can find the problem, but I'd say it'll be a quick trip into Nissan.
Jayson
EDIT: when I get the re-mapped ECU I'll eventually get it run up on a dyno to check A/F ratios, fuel pressure, detenation etc. And I'll post up the before/after results. Should be interesting (fingers crossed).;):)
  • 2 months later...
Bought a secondhand R33 ECU and plugged her in and all is good now.
Tacho works and ABS is working (light is off).
So the ABS computer must need the tacho output of the ECU to work. Just keep this in mind if your ABS stuffs up.
I pulled the cover off of the blown ECU and low and behold I totally cooked a resistor and a transistor got so hot, the solder holding it on melted and it dropped off the board.
After a quick look at the new ECU I found that the resistor was a 10 ohm 1/2 watt - about 10c from dick smiths !!!
I've put the resistor on, and soldered the transistor back on but I'm not sure if I should plug her back in to see if it's working.
BTW: surface mounted transistors are a pain in the butt to solder !!! See that little black thing in the top righthand corner with three legs on one side and one on the other, well it's about the size of a match head, and that's the sort of thing I had to solder....
I'm paranoid that I'll blow something else if it's not fixed !!!
J
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
