Still has round tail lights like a GTR but has extra 2 cylinders. Will give it a good clean and some paint as its fully vinyl wrapped.
Trip to the Dyno with a few more mods and ready for some fun next year.
Will post up some more images along the way of the strip down and clean up.
https://www.sau.com.au/forums/topic/432043-new-toy-has-arrived-from-usa/
Yes its a 2002 C5 Z06 Corvette, 5.7 LS6 motor and left hand drive. Its been racing in the US for around 5 years and finished 7th outright at the Corvette Nationals few years back. Has some good gear fitted all ready, with big oil coolers, accusump, gear box cooler and pumps, diff cooler, Willwood brakes, fire bomb, cool suit, coil overs, adjustable sway bars. 17x11 inch rims front and back and just picked up some Dunlop slicks to start some track testing.
Plans are to buy some extra parts bought a Corvette World Challenge front splitter and making a GT spec rear wing with rear diffuser.
Will get some 18" rims when I find some that fit nicely and use some semi slicks at time attack events as well.
Few more pics did take long to pull it apart...
  • 7 months later...
Wowzers....
A) Awesome car to race in.
B) Looks like an awesome place to live, and
C) How the hell do you choose which car to race in when you have a 35 in the garage?? I know which one I'd rather drive in the rain!
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
