Hey guys,
I'm in the midst of designing a toe/bump steer correction kit so that owners of 30 and 31 Skylines can run S13 coilovers with S13 uprights.
Would love to know how many are interested in this. Am thinking they'll be around the $150 - $175 mark, or I'll do them for $1300 with a set of G-Force coilovers.
I'll probably only get 10-15 kits made to start with so please let me know an idea of numbers.
Cheers
Peter
  • 3 months later...
Hey guys,
Here are the basic mockups of the bump steer correction kit (not finalised) and I've also created a rear coil over adapter - as you know S13 coilovers in the rear of a DR30 need to be at their highest setting (usually) just to get a lowered ride height (can't get a standard height) so I have created these that will bolt onto your coilovers so you have more height range adjustment, plus no need to drill holes as it converts from 2 to 3 hole.
Haven't worked out pricing yet but will be using top quality bearings on the bump steer kit which might drive up the price a little, but you don't want them failing on you!
Hey guys,
I'm finalising the design and these should be in production in March. Just some final measurement checks and also some dust boots for the bearings. The complete kit front/rear will be around $250 - $280 and will come with everything you need to grab your S13 front uprights, S13 coilovers and bolt them in.
Please note this is for the DR30. The R31 kit will differ slightly.
Looks like we have 5 interested guys here. I'll be producing 10 kits to start with.
I've made a design change. It came to my attention that the kit wasn't going to be IPRA legal (which is what I'm building my DR30 for). Tie rods ENDS are free, but I have to use standard tie rods (or from another similar car). The use a normal rod end would put too much strain in the shank, so I've designed my own tie rod end that takes a motorsport spec spherical bearing. The good news is its a more elegant design, although it might cost a touch more, it will be more robust.
  • 3 weeks later...
  • 1 month later...
Okay so the new design (not shown yet) is in production. Here is a replacement tie rod end (that takes a spherical bearing). I'll have the full batch by the end of the month, then have them in my car for testing asap.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
