Hey guys,
I'm in the midst of designing a toe/bump steer correction kit so that owners of 30 and 31 Skylines can run S13 coilovers with S13 uprights.
Would love to know how many are interested in this. Am thinking they'll be around the $150 - $175 mark, or I'll do them for $1300 with a set of G-Force coilovers.
I'll probably only get 10-15 kits made to start with so please let me know an idea of numbers.
Cheers
Peter
  • 3 months later...
Hey guys,
Here are the basic mockups of the bump steer correction kit (not finalised) and I've also created a rear coil over adapter - as you know S13 coilovers in the rear of a DR30 need to be at their highest setting (usually) just to get a lowered ride height (can't get a standard height) so I have created these that will bolt onto your coilovers so you have more height range adjustment, plus no need to drill holes as it converts from 2 to 3 hole.
Haven't worked out pricing yet but will be using top quality bearings on the bump steer kit which might drive up the price a little, but you don't want them failing on you!
Hey guys,
I'm finalising the design and these should be in production in March. Just some final measurement checks and also some dust boots for the bearings. The complete kit front/rear will be around $250 - $280 and will come with everything you need to grab your S13 front uprights, S13 coilovers and bolt them in.
Please note this is for the DR30. The R31 kit will differ slightly.
Looks like we have 5 interested guys here. I'll be producing 10 kits to start with.
I've made a design change. It came to my attention that the kit wasn't going to be IPRA legal (which is what I'm building my DR30 for). Tie rods ENDS are free, but I have to use standard tie rods (or from another similar car). The use a normal rod end would put too much strain in the shank, so I've designed my own tie rod end that takes a motorsport spec spherical bearing. The good news is its a more elegant design, although it might cost a touch more, it will be more robust.
  • 3 weeks later...
  • 1 month later...
Okay so the new design (not shown yet) is in production. Here is a replacement tie rod end (that takes a spherical bearing). I'll have the full batch by the end of the month, then have them in my car for testing asap.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
