Hi guys
I have a Blitz exhaust to suit V35 Skyline coupe (should also fit 350Z if you remove about 6inches of pipe length) for sale, located in SA. prefer local buyer but can arrange shipping and negotiate a cost for freight interstate.
Item: Blitz Y-pipe-back stainless steel exhaust to suit V35 Skyline coupe
Condition: Used. Average wear and tear. slight rattle in mid muffler. No holes or dents.
Reason For Sale:
i have recently ordered a Powerhouse Amuse R1 Titan exhaust hence i'm selling this one.
Description:
The exhaust came with the car when i bought it.
It looks subtle and sounds nice, just a bit deeper than stock and a nice growl in mid to high rpms. (obviously sound depends a lot on your other mods eg headers, cats/streight pipes, y-pipe, etc).
The exhaust is from the Y-pipes back (ie. it does not include the Y-pipe), and will bolt on to your existing Y-pipe.
It is a genuine Blitz exhaust, made in Japan, JASMA appoved. Fits nicely in the factory rear bar cutouts.
Currently still fitted to my car, will be off in the next couple of weeks. I will update with more photos when it has been removed.
Price: $300 or near offer.
post-91287-0-97800700-1379564379_thumb.jpgpost-91287-0-28132700-1379564411_thumb.jpgpost-91287-0-50951500-1379564428_thumb.jpgpost-91287-0-27622600-1379564460_thumb.jpg
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
