It's on kids.
Sunday 8th August.
12:30-1pm kickoff.
Beenleigh Showgrounds, Entrance 6 on Milne St. Map 284, B3 in the refidex, or check out whereis.com.au Show and shine, "Peoples Choice" awards, and a sound off, sponsors will be there to have a talk to everyone, can do membership on the day, buy shirts and stickers, we will do a raffle for car parts etc from the sponsors, and we will run a bbq and have drinks for sale (cheap) as well.
$10 admission fee gets you in, and gets you entry into any/all of the competitions you like.
We will run to 4:30pm at the latest. This is a very social laid back club, don't be afraid of putting your car in the show and shine, or going up to anyone and having a chat, or asking about their car, the social aspect of this club is great.
This is what we have been leading up to for so long.
Thanks to our sponsors, Tuff Toys, Automotive Technique, Bob Jane Tmarts, Cosmos Mechanical, and Brake Distributors Australia.
See you all there. 0411870159 if you get lost.
slip.
https://www.sau.com.au/forums/topic/43208-official-sau-qld-club-launch/
  • Replies 232
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
