  • Replies 232
good day, and good work by the organisers...
can we have a thread "how to become a member and member benefits" thread or something for lazy bums like me who didn't sign up today :D but wish to ...
Hey gordo the member ship cost's are
--->$95 gets u full years membership
1 Club polo shirt
3 Car Stickers the little ones I think
+ Club member ship card
--->$55 as above but with out the Polo Shirt
Show your member's card to get the discounts from our sponsers
"Bob Jane T Marts" (QLD stors only)
"Automotive Technique"
"Brake Distrubitors Australia"
"Tuff Toys"
"Mercury Motorsport"
"Cosmos Mechanical"
(4 people who did sign up today u will get Your member ship card & stickers in the mail)
Thanks guys for a well organised day.
It was good to see all the lines in one space again:wassup:.
Sorry I had to bail, wish I could've stayed longer but kids had to go home to Caloundra.
Congrats to "SHY" well deserved for the peoples choice.
Thanks again, looking forward to the next get together.
PS: the kids had a good time too.:D
Cheers Chris, AKA CYA34.
SAUsage sizzles rock. I think I had about five. Good day out, beautiful weather for it. more thanks for organizers and congrats to all winners. Suprised only 4 ppl joined club (incl me) yesterday. did I read that right? How many members are there? did everyone join earlier? huh? :D
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
