  • Replies 232
It is definitely happening. Slip is putting together a detailed post with all the info you'll need, it should be up later today.
It wasn't left to the last minute, this kind of thing is very time-consuming and we have lives too. The venue, sponsors etc have been organised for some time, but as always there have been some minor but important details that held things up. These have been sorted thanks to Gary and Slip - allowing the day to go ahead as planned. Inaugurating a club isn't a simple case of wandering into a building a filling out a bit of paper with the club name on it. There is a shiteload more than that involved, all of which somehow has to be organised between work and personal commitments. Props to Slip and Gary for managing to do it.
The detailed post a bit later on will answer most other questions :)
Check qld forum for an alert thread regarding the launch, and the original post in this thread has been edited. I've been trying for weeks to organise a time with the lady who books the venue. I sent her the money ages ago, but only just got her to meet with me. Doing it just a week away has it fresh in everyones head too.
what if we meet at mister pies carpark at cannon hill plaza around 9ish and leave at about 20 past 9 any problems or questions lets us know
Start time has changed to 12:30
Lets make it 11:00 - 11:30 meet for a 12:00 departure.
At Mr Pies.
For East/South side people.
We'll wait if Northsiders are coming through that way,
or can meet northsiders on the Gateway?
Every time I go past there I sing the "Mr Plow" song, substituing "Mr Pies"
Mr Pies thats my name,
that name again is Mr Pies!
I had a great idea of all meeting up somewhere and then invading Beenleigh wit hSkylines from all directions :P then I woke up and realised that it would require two things effort and organisational skills, of which I lack greatly ;)
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
