I understand that they have inbuilt ignitors in the coilpacks, and have the signal from the CAS to fire, BUT if you were to use the s1 loom using the EXTERNAL IGNITOR with the s1 coils, will I be able to do this? I can sell the coilpacks, but I'm I want to see if it can be done, the coils are less than 2000km old, it's cheaper If I can go this way and to be honest in my opinion integrated ignitors on coilpacks is a more un reliable set up as it's introducing further heat to a area which is prone to cracking ect ect, it's not so much about $$ but more so using what I have and reliability
Cheers
the connection wont fit. but if you get the ignitor loom, and coil loom you can cut and wire it in manually. a good tuner electrician should be able to do this without any issues.
but you are better off trying to find someone who would be keen to swap the s1 coils for a s2 set.
by the time you wire it all up its going to be better to just sell the coil packs and buy a proper series 2 set.
Cheers guys, I'm not to bad with electrical, I just wasn't sure if the ecu wouldn't read it or if it was throwing out different voltages ect ect, so in saying that I should be able to do it,
Thanks alot, appreciate the help
The ECU sends the same signals out regardless of which coils/igniters are at the other end of the loom. It's just that the wires run direct from the ECU to the coils in the S2 case and have to stop off at the igniter in the S1 case. In the same way, the various igniters don't much care which ECU is telling them to fire, and they also don't much care which coil they're then firing (assuming separate coil and igniter), unless the coil also has an igniter, which is not so good.
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
