I understand that they have inbuilt ignitors in the coilpacks, and have the signal from the CAS to fire, BUT if you were to use the s1 loom using the EXTERNAL IGNITOR with the s1 coils, will I be able to do this? I can sell the coilpacks, but I'm I want to see if it can be done, the coils are less than 2000km old, it's cheaper If I can go this way and to be honest in my opinion integrated ignitors on coilpacks is a more un reliable set up as it's introducing further heat to a area which is prone to cracking ect ect, it's not so much about $$ but more so using what I have and reliability
Cheers
the connection wont fit. but if you get the ignitor loom, and coil loom you can cut and wire it in manually. a good tuner electrician should be able to do this without any issues.
but you are better off trying to find someone who would be keen to swap the s1 coils for a s2 set.
by the time you wire it all up its going to be better to just sell the coil packs and buy a proper series 2 set.
Cheers guys, I'm not to bad with electrical, I just wasn't sure if the ecu wouldn't read it or if it was throwing out different voltages ect ect, so in saying that I should be able to do it,
Thanks alot, appreciate the help
The ECU sends the same signals out regardless of which coils/igniters are at the other end of the loom. It's just that the wires run direct from the ECU to the coils in the S2 case and have to stop off at the igniter in the S1 case. In the same way, the various igniters don't much care which ECU is telling them to fire, and they also don't much care which coil they're then firing (assuming separate coil and igniter), unless the coil also has an igniter, which is not so good.
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
