Guys,
My e-boost is set now so that when i run SP3 (highest boost setting 17psi) the car reaches it in every gear. First gear wheelspins around 4000rpm and I need to change gears and dont have full boost in second which makes the car a lot slower. I would love to run 12-14psi in 1st gear and then 17psi in the other gears.
Is this possible with the e-boost?
The instruction guide is useless to me.
Evan
https://www.sau.com.au/forums/topic/43209-e-boost-question/
You can't program it to run differet boost in different gears. What you can do is set it up with SP2 andSP3 hardwired to switches. I have 2 rocket switches in the centre console just in front of the storage compartment 1 green and 1 red. My normal everyday boost is 14.5psi, flipping the green switch brings up SP2 at 18psi and the red one SP3 at 22psi.
So use normal boost in first then change to 2nd and as your hand comes off the gearlever it falls to the switches and you flip on whichever one you want.
https://www.sau.com.au/forums/topic/43209-e-boost-question/#findComment-882317
The latest in Hi-tech electronics, featuring a 16 bit RISC based FLASH memory CPU – faster and smoother boost response
Utilises the latest in surface mount technology – lighter, smaller and ultra compact
Electronics are housed in an anodised billet aluminium alloy housing – offering durability and reliability in harsh race conditions
Programmable gate pressure function to totally eliminate wastegate creep - you tell the wastegate when to open
Three internally or externally activated and individually programmable boost set points
Drag racers - improve your launch, run a different boost in each gear
High accuracy boost and vacuum display, readout accurate to within +/- 0.5% of full scale, boost gauge no longer required – great value
Readout can be tailored to suit your needs – display can be configured in KPA, Bar or PSI
Easy to read seven segment display with programmable bar graph and glow in the dark buttons
Programmable auxiliary output – e.g. water spray control, water/methanol injection, boost light
Programmable audible warning alarm – excellent for over-boost warning or full boost confirmation
Peak hold/Max Boost recall function
Revolutionary gauge type construction allows many practical mounting solutions – 66mm in diameter 55mm long. Suitable for Panel mounting, or in any 2 5/8 inch gauge pod or pillar mounting system.
unless that means exactly as you describe without pointing out that it requires additional wiring etc, if so i stand corrected
https://www.sau.com.au/forums/topic/43209-e-boost-question/#findComment-882639
Guys,
Evan
I use the throttle to control the wheelspin :thankyou:
https://www.sau.com.au/forums/topic/43209-e-boost-question/#findComment-882640
thanks for the replies.
in the guide it has a section about the sensitivity.
Automatically set to 10. Adjustments can be between 0-99.
Sensitivity too low - Achieve more boost in high gears
- Takes longer to achieve boost set point
- Boost drops off at higher RPM
Sensitivity correct - Boost rises quickly and is steady
Sensitivity too high - Boost pressure fluctuates, cycles or is not smooth
- Boost pressure overshoots set point - rises too fast
51jay, Good idea I might have to look in to that, thanks.
Jimbo, I guess if thats what it says I will ring them.
Sydneykid, yeh trying that, I need more skills.
Thanks guys
If anyone does know how else to do it please reply.
I will ring turbosmart and see what they say and update the thread.
Evan
https://www.sau.com.au/forums/topic/43209-e-boost-question/#findComment-882685
Quote
Well you could do it in 3 gears as e-boost has 3 available settings for boost level, however e-boost will not change between these boost levels for you . You have to exhert yourself either by pressing the up/down buttons on the e-boost itself or by hardwiring sp2 and sp3 through a switch or switches. e-boost defaults to sp1 when turned on.
rb20-calais you really need to set it up on a dyno or if on the road...with someone who knows what he's doing it's mostly a trial and error thing so make sure you have a reasonable overboost cut set befor you fiddle
https://www.sau.com.au/forums/topic/43209-e-boost-question/#findComment-882897
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
