Hey.
Just had a crack at changing my timing belt on the rb25 and my crank pully keeps breaking f$(ckn cast jap crap pulleys.
I'm useing a three swinging finger type puller. never had trouble on cars with real pulleys lol these things are crap!!
Any suggestions in getting this thing off before my don't f$&k with me hammer comes out!
Tried to wd it tighten back up and lossen, hitting it with timber. Doing my head in. So much for my quick belt change.........
https://www.sau.com.au/forums/topic/432149-timing-belt-change-gone-bad/
Yeh gotta do your research before pulling things apart and blaming the manufacturer when you do something wrong...
Nissan crank pulleys don't use the claw pullers. You use the two threaded holes on the front.
  • Like 1
UNF is imperial not metric
Indeed. Metric is metric coarse and metric fine. Imperial is UNC and UNF. Glad this was here for me to read I'm doing my belt next year.
Just adding you the metric thing, thhere isn't just one fine option in metric, there's quite a few. If the pitch isn't specified it is always coarse. If it is a fine thread the pitch would be specified.
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
