Hi peeps, I recently bought my first Skyline with some damage to the drivers corner. Panel work is done (: so i started looking at the engine. I started the car and the idle was rough with it idleing high and low very quickly I noticed that one of the injectors where leaking so I pulled them out got my injector guy to have a look at them and he found two to be faulty and need replaced. I got 2 injectors and serviced them and wacked them back in. Started the car it has fixed the rough idle car still seam's to be a little out on idle but rev meter says 900rpm and it idles high and low???? Has anyone had this issue help would be very much appreciated. Thanks guys
I have gone over my hose's with carby cleaner, Blocked my BOV (put a plate over the gasket) and checked my wastgate (not seized)
https://www.sau.com.au/forums/topic/432154-r32-rb20det-idle-problem/
I removed the ACC and cleanded the buid up (there was abit of oil or carbon) still has a bad idle (reving up and down)
I tryed to locate the IAC but couldnt find it but with some help from a helpfull message that was sent from a SAU user (thanks again for the info)
I turned my attention to the air regulator I blocked it started the car and it is still has a bad idle
ok guys bit of a mix up by me. Instead of taking off the ACC and cleaning the spring and screw i pulled off the ACC solinode. I just cleaned it and put it back together thanks to DIY search and I then begun to set the idle screw. I disconnected the ACC plug and I found myself closing the screw all the way down to get to 900rpm i open it abit and now im getting 950rpm but car gets to 1200rpm even 1500 sometimes. this happens when i give it abit of throttle car dosnt react when i brake or turn the stearing wheel.
ok guys this is where I am today. I went over the intercooler hoses and clamps, cleaned my AFM, cleaned the BOV, cleaned the ACC (spring and screw), cleaned the IAC valve and cleaned the throttle body. after doing all this started the car and same result (idle floats between) 900 and 1200rpm.
I also remembered that a SUA user mentioned the injector seal on the manifold I found that number 1 injector is leaking from the top part of the injector. I removed it and swiched the seals with number 2 and number one still leaked. My injector guy will receive a very happy call tomorrow. I have tryed to set my idle screw (ACC) but cant get a good idle I think due to the injector leaking.
oh I also pumped the brakes continues and the idle went down pretty fast??? I think the booster has a vac leak causing this idle???
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
