nah im out all weekend and baby shower on sunday so yer ill be at my olds though i was playing around with my AFM my mate said that he heard that S1 AFM can unsolder on the plug dunno how true this is as i see no phsyical difference apart from a colored sticker from S1 and S2 afm Mine is green s2 is pink.
Now started my car and it died would crank over unplugged AFM started ran for at least 5 mins on a bumpy idlebut mostly above 500rpm i also gave it a rev np it wouldnt make boost and alsi seemed like it cut at about 2000-2500rpm this is from engine bay cable rev now i turn it off i gave my AFm a clean again let it dry plugged it back in started it as soon as i reved it it just died and also didnt seem like it was making boost (also led me to think a cooler pipe had split or blown off) but on a switch off then back on again i had boost this is all while AFM was plugged in then it died...unplugged my AFM started it idled without dieing for at least another 5 mins gave it a few hand revs and it still didnt die until i turned it off....So im thinking this problem is AFm isolated OR the plug or AFM loom.
i seen on ebay S2 AFM Pink and orange sticker for like $80 should i invest in one of these will they work on my S1 looks like some come with a brand new plug aswell.
Edited by HYBRID VL
Ok pulled the AFM apart i noticed that the plugs wasnt so tight in but more on one side then the other so after getting the plug off i filed all the prongs on the board and the plug to clean them up and got all the old solder off i then resoldered the prongs back on then tested with a multimeter to make sure power was running through it all four prongs were conducting nicely so i pluggged it back in started the car 1st start run np alil jumpy on idle but could be semi fouled plugs nothing major and did not stall at all seems all good so i put the top plastic lid back on siliconed it around the edges gave the inside of the AFM a generous blasting of Contact cleaner and its sitting in my garage ready to go back on tomorrow with the Pod filter lets hope my problem is solved.
just installed it all back in my car started it ran did do the bouncing idle but hasnt stalled yet after about a 8min idle plugs could be dirty so il change them next.
  • 1 month later...
Just to let you all know my problem is now fixed cleaned the AFM with CC and also resoldered the plug inside onto the board and resiliconed it on the top so far so good.
Edited by HYBRID VL
Just for others reading this thread, it should be noted that some contact cleaners contain a very small amount of lube, while proper Air Flow Meter cleaner does not, you really need to avoid using the lubricated cleansers.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
