Hi
My drivers side electric window motor seems to be on the way out so I thought I would open it up and check if a DIY fix is possible.
The panel/trim came off without to much bother but getting to the motor and mechanism seems to be impossible due to it being behind the inner metal door skin which does not seem to unbolt and in fact seems to be spot welded to the outer door skin.
Does anyone have any advice on how to get the motor and mechanism out?
Thanks
Stretch
https://www.sau.com.au/forums/topic/432231-r34-gtr-side-window-motor-access/
Can you post up a picture or 2 ? There must be access of some sort as the motor wouldve been put in there after the inner and outer skins wouldve been spot welded together on the assembly line
You have to unbolt the glass from the rails first.
There are access holes on the inner skin to get to the various bolts depending on the position of the window slider rails.
The large hole is basically where you pull the reg assy out after setting it up so it is 'compact' to remove.
A workshop manual would be really handy right now!
GTRsean , on closer inspection you are correct, there is space to unbolt and remove the mechanism/motor.
Do you think the plastic sheet that is glued to the door skin is really needed when putting the door card back on?
But more importantly it looks like cleaning and greasing the tracks for the window is going to sort the issue out, so hopefully no need for a new motor.
I will confirm after the weekend.
  • Like 1
Yes it is really needed otherwise it wouldnt be there in the first place, the goop holding it on is soft so if you carefully peel it back when accessing that area then it should be okay to put back on
When you wash the car a certain amount of water makes it's way past the window glass and seals, then it drains out the bottom of the door.
The plastic sheet helps with moisture control so that the door trim doesn't slowly rot away :)
Most new cars don't have it because the door trim is all plastic...
So I managed to grease all the relevant tracks and pivots and the window is now working OK.
Was so much faster it highlighted that the passenger side needed doing as well.
Also got the plastic sheet back on OK.
Thanks for the input gents
  • Like 1
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
