G'day I'm kenny.
I've been told i've made a terrible purchase in buying the r33 that i have bought by a few performance shops, IMG_0381_zps7a2a9b4b.jpg IMG_0379_zps763a250c.jpg
and i'm licking my wounds trying to revert the work that's been done to the car to get it back to being safe. I need help because honestly i'm way in over my head
to go into this with no knowlage about turbos or rb25's. Right now as the car is, it has NO boost control at all, with a truck turbo, powersteering hose for oil on and angle (gravity fed), stock ecu, pops intercooler pipes (my failsafe for overboost O_O), and theres an oil leak at the bottem near the exhast manifold from i assume powersteering hose?
So what i've been told is the most cost effective way to get this car back to a safe tune without blowing up my engine is to revert everything back to stock and start from there. So i've bought r33 turbo + dump pipe + manifold+airflow seonsor and a fresh new intercooler kit for stock r33's, how should i go about installing it? where is the turbo located on a stock rb25det? (this guy moved the turbo). Can someone explain starting from the throttle body all the parts to the dump pipe+pod filter? (what part goes where). will i need any special tools? things to avoid? What piping needs to be replaced (braided lines)?
If you see anything unsafe in the pictures let me know aswell please
Edited by iTwix
https://www.sau.com.au/forums/topic/432248-reverting-to-stock-help-gts-r33/
You could get a Hypergear and computer package and buy my injectors and be laughing rather than reverting to stock.. selling some of that gear and you'd be half way there and happy days
get some spacers for the brakes, intercooler looks good from pic
Edited by AngryRB
My budget has come to a sudden halt after buying all the stock parts, i have a plug play ecu that i can install after i get the stock turbo back in to mess with upgrades when i can afford them.
i have these to go back to stock, is this everypart i'll need?
[url=http://s113.photobucket.com/user/jaggedspiker/media/IMG_0392_zpsf0872199.jpg.html]IMG_0392_zpsf0872199.jpg[/url
also havedump pipe to ehaust
Edited by iTwix
which ones? i know the intercooler piping isn't because stock is a sidemount, but it's a it for the stock setup. Stock turbo.. what else isn't?
Dump pipe also isn't stock... Looks like a split dump to me :)
is that bad/good? does that mean i'll need a different exhaust size?
From this end it looks like a stock flange... Throw up some more detailed photos of the dump and measure the end of it to see how big it is :)
With more detail I might be able to give you some helpful advice ;)
Front mount intercooler isn't stock but I guessed you knew that
I may have missed it previously but why do you want it stock anyway?
Well, that dump is definitely a split dump, intended to be an exact replacement for the standard dump. So if you have the downpipe that goes between the dump and the cat, then you will be able to bolt it all up to a standard turbo on a standard manifold.
Those cheap arse short split dumps are not the greatest, but it will work, provided the wastegate flap still moves properly. So when you fit it up, make sure the wastegate swings freely. If it doesn't, put the split dump in a metal recycling bin and go grab a standard one for (nearly) free from any workshop that has worked on an RB engine.
I want it stock because right now it's running a massive turbo on a stock ecu (dangerous), 60% of all pipes are held with basic radiator clamps and old joiners with plastic pipes(dangerous), the blue pipes you see in the photo comingout the top of my engine (not sure what they have inside of them) are bad qaulity and crimping whilst not being clamped, i have no boost control/wastegate on this turbo (if you look at the stock turbo i have the waste gate to remove pressure). Right now i can't rev past 4k rpm because my turbo spools uncontrollibly and the pipes wont hold, so i have to pull over and attach the intercooler hoses back on, but all the tuning shops i went too said i should stay off boost completely until i get boost control sorted. And if i tear everything that has been done and go back to stock i'll have a rb25det that can be red lined without worrying of fuel cut or overboost, or my enginge blowing up. and i'll know there wern't any shortcuts taken so things wont break.
Edited by iTwix
i cleaned the factory turbo out, checked play (5mm), and checked waste gate/actuator and everything operates fine, waste gate opens when you pull on the metal line going to the actuator(spring). I also need to know where the vacum line goes too from the actuator.
Is this my downpipe?
and could you idetify the (?) part? also that metal oil line, what does that attach too?
Edited by iTwix
Dude where are you located? It sounds like you have no idea whats what and it might be better for one of us more technically minded SAU's to come have a look and help you.
Probably save you alot of $$$ in the long run.
Pm me if need be.
Pm me if need be.
Looks like WA plates.
The dude has made a boo-boo. Would be good if someone who knows what's what could meet him in person and give him a few pointers. I'd happily do it but haven't got any plans to travel to WA anytime soon, and by soon I mean ever.
  • Like 1
doesnt look as bad as you think....for starters Its an external gate turbo mate...look under the turbo you will see another pipe separate from your turbo with a wastegate on it, i can see it in the picture if it has a 14psi spring in it well technically that is your boost control..its not ideal but it does work....
Just sort your intercooler piping out so it doesn't pop.....buy an aftermarket ecu and get a tune...should make some sort of decent power, the only reason it is freaking out at 4000rpm is because of the computer...
as for brakes rubbing just buy some wheels spacers to move them out a bit...
Oh yeah get a braided oil feed line :rofl:
Honestly it just looks like your typical.slap.job someone has put together in their backyard and then realized they need to spend 3k on a ecu,injectors and a tune...so they gave up
  • Like 1
You pick up a signal for the wastegate actuator either off the nipple on the front cover of the turbo (compressor housing) if it has one, or off a nipple in the compressor outlet pipework.
That pipe might be the downpipe. The photo is so bad it could be anything.
The question mark thing looks like the compressor outlet elbow. It bolts onto the compressor outlet to turn the flow 90° towards the front of the car for the stock cooler piping.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
