G'day I'm kenny.
I've been told i've made a terrible purchase in buying the r33 that i have bought by a few performance shops, IMG_0381_zps7a2a9b4b.jpg IMG_0379_zps763a250c.jpg
and i'm licking my wounds trying to revert the work that's been done to the car to get it back to being safe. I need help because honestly i'm way in over my head
to go into this with no knowlage about turbos or rb25's. Right now as the car is, it has NO boost control at all, with a truck turbo, powersteering hose for oil on and angle (gravity fed), stock ecu, pops intercooler pipes (my failsafe for overboost O_O), and theres an oil leak at the bottem near the exhast manifold from i assume powersteering hose?
So what i've been told is the most cost effective way to get this car back to a safe tune without blowing up my engine is to revert everything back to stock and start from there. So i've bought r33 turbo + dump pipe + manifold+airflow seonsor and a fresh new intercooler kit for stock r33's, how should i go about installing it? where is the turbo located on a stock rb25det? (this guy moved the turbo). Can someone explain starting from the throttle body all the parts to the dump pipe+pod filter? (what part goes where). will i need any special tools? things to avoid? What piping needs to be replaced (braided lines)?
If you see anything unsafe in the pictures let me know aswell please
Edited by iTwix
https://www.sau.com.au/forums/topic/432248-reverting-to-stock-help-gts-r33/
You could get a Hypergear and computer package and buy my injectors and be laughing rather than reverting to stock.. selling some of that gear and you'd be half way there and happy days
get some spacers for the brakes, intercooler looks good from pic
Edited by AngryRB
My budget has come to a sudden halt after buying all the stock parts, i have a plug play ecu that i can install after i get the stock turbo back in to mess with upgrades when i can afford them.
i have these to go back to stock, is this everypart i'll need?
[url=http://s113.photobucket.com/user/jaggedspiker/media/IMG_0392_zpsf0872199.jpg.html]IMG_0392_zpsf0872199.jpg[/url
also havedump pipe to ehaust
Edited by iTwix
which ones? i know the intercooler piping isn't because stock is a sidemount, but it's a it for the stock setup. Stock turbo.. what else isn't?
Dump pipe also isn't stock... Looks like a split dump to me :)
is that bad/good? does that mean i'll need a different exhaust size?
From this end it looks like a stock flange... Throw up some more detailed photos of the dump and measure the end of it to see how big it is :)
With more detail I might be able to give you some helpful advice ;)
Front mount intercooler isn't stock but I guessed you knew that
I may have missed it previously but why do you want it stock anyway?
Well, that dump is definitely a split dump, intended to be an exact replacement for the standard dump. So if you have the downpipe that goes between the dump and the cat, then you will be able to bolt it all up to a standard turbo on a standard manifold.
Those cheap arse short split dumps are not the greatest, but it will work, provided the wastegate flap still moves properly. So when you fit it up, make sure the wastegate swings freely. If it doesn't, put the split dump in a metal recycling bin and go grab a standard one for (nearly) free from any workshop that has worked on an RB engine.
I want it stock because right now it's running a massive turbo on a stock ecu (dangerous), 60% of all pipes are held with basic radiator clamps and old joiners with plastic pipes(dangerous), the blue pipes you see in the photo comingout the top of my engine (not sure what they have inside of them) are bad qaulity and crimping whilst not being clamped, i have no boost control/wastegate on this turbo (if you look at the stock turbo i have the waste gate to remove pressure). Right now i can't rev past 4k rpm because my turbo spools uncontrollibly and the pipes wont hold, so i have to pull over and attach the intercooler hoses back on, but all the tuning shops i went too said i should stay off boost completely until i get boost control sorted. And if i tear everything that has been done and go back to stock i'll have a rb25det that can be red lined without worrying of fuel cut or overboost, or my enginge blowing up. and i'll know there wern't any shortcuts taken so things wont break.
Edited by iTwix
i cleaned the factory turbo out, checked play (5mm), and checked waste gate/actuator and everything operates fine, waste gate opens when you pull on the metal line going to the actuator(spring). I also need to know where the vacum line goes too from the actuator.
Is this my downpipe?
and could you idetify the (?) part? also that metal oil line, what does that attach too?
Edited by iTwix
Dude where are you located? It sounds like you have no idea whats what and it might be better for one of us more technically minded SAU's to come have a look and help you.
Probably save you alot of $$$ in the long run.
Pm me if need be.
Pm me if need be.
Looks like WA plates.
The dude has made a boo-boo. Would be good if someone who knows what's what could meet him in person and give him a few pointers. I'd happily do it but haven't got any plans to travel to WA anytime soon, and by soon I mean ever.
  • Like 1
doesnt look as bad as you think....for starters Its an external gate turbo mate...look under the turbo you will see another pipe separate from your turbo with a wastegate on it, i can see it in the picture if it has a 14psi spring in it well technically that is your boost control..its not ideal but it does work....
Just sort your intercooler piping out so it doesn't pop.....buy an aftermarket ecu and get a tune...should make some sort of decent power, the only reason it is freaking out at 4000rpm is because of the computer...
as for brakes rubbing just buy some wheels spacers to move them out a bit...
Oh yeah get a braided oil feed line :rofl:
Honestly it just looks like your typical.slap.job someone has put together in their backyard and then realized they need to spend 3k on a ecu,injectors and a tune...so they gave up
  • Like 1
You pick up a signal for the wastegate actuator either off the nipple on the front cover of the turbo (compressor housing) if it has one, or off a nipple in the compressor outlet pipework.
That pipe might be the downpipe. The photo is so bad it could be anything.
The question mark thing looks like the compressor outlet elbow. It bolts onto the compressor outlet to turn the flow 90° towards the front of the car for the stock cooler piping.
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
