Oh yeah get a braided oil feed line :rofl:
Honestly it just looks like your typical.slap.job someone has put together in their backyard and then realized they need to spend 3k on a ecu,injectors and a tune...so they gave up
which oil line? the turbo gravity feed? or engine oil? i want to replace the majority of the pipes, i just need to know the important ones to change over >_<
This injectors tune ecu boost controller and pipes shouldn't be more then 2 grand get it done and you will have a very capable street car some bolt on spacers to fix wheels rubbing shouldnt be more then 50 bucks
I don't have 2 grand, my budget died after buying the stock parts, i'm in this build now. I'm hoping to learn how to build this car properly so i know it inside and out as the rb25 was freshly rebuilt, if i can build back to stock, oposed to upgrade the car will last a lot longer spending alot less money.
Note: i'm not in it for the horsepower, just a safe running car that has very clean new stock parts.
Edited by iTwix
I want it stock because right now it's running a massive turbo on a stock ecu (dangerous), 60% of all pipes are held with basic radiator clamps and old joiners with plastic pipes(dangerous), the blue pipes you see in the photo comingout the top of
my engine (not sure what they have inside of
them) are bad qaulity and crimping whilst not
being clamped, i have no boost control/wastegate
on this turbo (if you look at the stock turbo i have
the waste gate to remove pressure). Right now i
can't rev past 4k rpm because my turbo spools
uncontrollibly and the pipes wont hold, so i have
to pull over and attach the intercooler hoses back
on, but all the tuning shops i went too said i
should stay off boost completely until i get boost
control sorted. And if i tear everything that has
been done and go back to stock i'll have a rb25det
that can be red lined without worrying of fuel cut
or overboost, or my enginge blowing up. and i'll
know there wern't any shortcuts taken so things
wont break.
Ah understand. .you dont have to return it to stock to get it running right. No offense but sounds like you are randomly buying parts and hoping for the best outcome, as others have said, ask a fellow sau member to take a look at what bits you have /actually NEED before you waste anymore money
Also keep in mind that spacers for your wheels are illegal and defectable
Not sure why others on here are even suggesting you use them when other options are out there
Edited by StevenCJR31
pretty much dude, i bought a dump pipe that i'm not sure will bolt on to the exhaust, as it's 3" all the way through right now :( But i've seen stock exhausts on gumtree for 100 bucks so it's drivable
lol....just about any mod is defectable ...^^^ sorry Steven but this is probably the stupidest statement ever made on sau because half the cars on here are running spacers and I dont see wheels flying off everywhere do you????????????? :rofl:
that rubber hose going into the turbo mate...look all you really need to do is replace that and get a decent tunable ecu...and stop your intercooler pipes falling off...it should run fine...sell all that crap u just bought...sell those wheels that dont fit properly...put money towards ecu and a tune and you have a powerful car...easy ;)
Whats with the personal attack there artz? Do you have little weiner syndrome or maybe small man syndrome?
I merely pointed out the legalities of spacers NOT the safety side of things and unlike most mods the spacers can be seen from outside of the car
A very small amount of metal machined off the back of the wheels will fix clearence issues
Remember to add lots more question marks as it really helps get your point across
no personal attack meant mate, I just found it amusing that you point out the legalities of a small wheel spacer to someone running wheels that are too wide regardlessm and a top mount turbo with external gate etc etc...i think a 5 mm wheel spacer is the least of his problems dont you ;).. and all legalities aside what is more unsafe, a wheel spacer, or a wheel that rubs on the brake caliper....?
Of course he can / will get away with the spacers but my point is they can be seen from the outside of the car -cops look for these things- unlike his top mount / ext gate which is outta sight and out of mind and wont be heard unless he drives like a tool
have a permit for BOV, front mount and pod filter, althought right now i have a 3" straight pipe. Believe me man, if i could bolt that split dump i have to the straight pipe and be done i would, but i'm not sure if they'll fit as the dump looks 2"-2.5"
Exactly fix what you've got rather that buying more parts you don't need please we are trying to help you
right now i'm sure 50% of the pipes cause a vacum leak as they're barley held together with radiator clamps, which is why i have the new intercooler+ kit for the piping + silicon joiners and proper clamps, i'm pretty sure i could install the new intercooler and half the piping right now. It's just i want to make sure i have the parts for the stock turbo before i take it all apart and need to know where things were supposed to be so i can figure out everything that's been modified on my bay for the install.
Just mock fitting a few parts so i can get the general idea and i've noticed i don't have bolts from the dump pipe to the turbo or the turbo to the90 degree manifold, does anyone know where i can get them?
i found a blow off valve hiding under the exhaust manifold is it worth using? IMG_0428_zpse38b8476.jpg
also need to know what part that belongs betwen the throttle body and the intercooler piping, or can i cheat and use a silicon 90 degree bend? 24a71ac7-1e1d-458a-9234-daa2d9acb411_zps
my piping is held together with radiator clamps and has held over 40psi....your point is invalid...
if there is no bead around the end of your cooler piping that would be your problem not the clamps....
My pipingis old and rusty, the joiners are stretched and the hose clamps arn't on straight. Don't underestimate on how shit a job can be completed!
Any metric bolt store should be able to help you
There is a good one in the industrial area close to the intersections of collier road/guildford road bassendean
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
