I would walk into an exhaust shop or performance workshop carrying that turbo and exhaust kit and ask to buy sufficient suitable fasteners to hold it all together. The dump is usually held on to the turbo outlet with a mixture of bolts and a couple of studs (due to lack of access to get bolts through). The dump onto the down/front pipe will want decent fasteners that can take the heat. (Same with the turbo-dump fasteners for that matter, plus you want to have decent dome washers or locking fasteners or lock tabs or something to stop them coming loose and falling off).
That "blow off valve" is not a BOV, it is a wastegate, which you won't need if you swap back to standard turbo.
Your question marked blue hose elbow needs to be replaced with the original cast alloy crossover pipe, if that is what your new cooler piping kit is intended to hook up with. The cross over pipe also has the point where you put the BOV, plus it has some tapping points used for connecting parts of the emissions gear. If you put a factory BOV onto the factory cross over, you'll also need to put in the pipework to take the BOV outlet back to the turbo inlet.
I tend to agree with the other guys here. You would be better off getting the stuff you have on the car working than trying to go back to stock. Too many niggly things you need to do it right.
The wheels issue is best solved by pissing them off and fitting either stockies or aftermarket ones that actually fit. There is very little reason to use spacers to make the wrong wheels fit beyond appearance/fashion, and cars should not be made to look in a particular way at the expense of functionality. To do so is to not masculine.
Edited by GTSBoy
Also keep in mind that spacers for your wheels are illegal and defectable
Not sure why others on here are even suggesting you use them when other options are out there
edit. point has been made and discussed.
^^ this! get someone (any furkn one!) who can sort this for you
You are trying to use a combo of stock and aftermarket parts(some good and some not) and trying to make it work for you
The way you are approaching this is going to end in tears and an empty wallet
You really don't listen to anything I have tried to tell you do you...GL with it champ....you'll need it :thumbsup:
Sorry, couldn't get a good look at the object as it was under my manifolds and i'm new to turbos/ wastegates, it looked totally different to the stock one.
thank you for the information, it was very helpful. i might take everything i have into a shop and see what they can do.
Heres a video on how it runs for anyone that's intrested:
[uploading]
Edited by iTwix
Agreed, its like he is missing all the advice thrown his way
i'm listening to a lot of information. I came into this thread without knowing any of the fuctions of the parts i had, now i know exactly what they do and exactly what i need to achive the build.
i apreciate all comments negative or positive
and we appreciate your thread ....you know, for the larfs it has brought us
i hope you get it going one way or another coz it actually looks like a nice 33 ... :thumbsup:
dave your a kent. but i love ya.
mate. seriouslsy. you are not listening.
put down your tolls, wallet, shitty parts. ask for a pm from someone close to you. call them. let them look. write down what they tell you needs to happen. do it.
pull farkin skids farken.
i've had 2 people from jap car clubs to come have a look at it, and i've taken it to various performance shops recommended by others.
what you need is some under bonnet pics of a stock standard engine bay then go search for the parts, quite simple really
im returning mine to stock and will take some pics for you..
some more pieces to your puzzle
Edited by AngryRB
UPDATE: just blew the old turbo, defiantly rejoicing over my decision to buy stock turbo. Glad i didn't throw on fuel rails and try to tune that setup, like some suggested haha.
Question: can i limp a blown turbo around if i stay off boost for a week?(no smoke yet)
Edited by iTwix
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
