Page34 Posted September 23, 2013 Share Posted September 23, 2013 hey guys, wondering if anyone has come across this noise before my na r34 make a whining noise at almost exactly 80km/h in 5th gear at about 1/4 throttle, it sould like i could be comming from the gearbox, cheaked oil levels and all seams fine if anyone has heard this would love to find out what it is and if there is a fix cheers Link to comment https://www.sau.com.au/forums/topic/432249-r34-whining-at-80kmh/ Share on other sites More sharing options...
niZmO_Man Posted September 24, 2013 Share Posted September 24, 2013 Diff? Link to comment https://www.sau.com.au/forums/topic/432249-r34-whining-at-80kmh/#findComment-7034310 Share on other sites More sharing options...
Page34 Posted September 24, 2013 Author Share Posted September 24, 2013 probably, how could i cheak that? would it be a lack of diff oil or something messed up internally Link to comment https://www.sau.com.au/forums/topic/432249-r34-whining-at-80kmh/#findComment-7035060 Share on other sites More sharing options...
kosmo90 Posted September 24, 2013 Share Posted September 24, 2013 Wheel bearings? Link to comment https://www.sau.com.au/forums/topic/432249-r34-whining-at-80kmh/#findComment-7035071 Share on other sites More sharing options...
niZmO_Man Posted September 25, 2013 Share Posted September 25, 2013 probably, how could i cheak that? would it be a lack of diff oil or something messed up internallyIf it's only doing the while in one gear (e..g 5th) then you can point at the gearbox. If it's whining in whatever gear at that speed (e.g. drop it to 4th and 3rd) then it's most likely diff. Does it whine under load or all the time (e.g. lifting off going downhill)? Link to comment https://www.sau.com.au/forums/topic/432249-r34-whining-at-80kmh/#findComment-7035638 Share on other sites More sharing options...
gtsttrk Posted September 25, 2013 Share Posted September 25, 2013 Wheel bearings? Yeah that was my first though when I saw this thread. I'd say check wheel bearings, though it does sound a bit strange that it's happening in a specific gear - in terms of wheel bearings. Link to comment https://www.sau.com.au/forums/topic/432249-r34-whining-at-80kmh/#findComment-7035666 Share on other sites More sharing options...
Sinista32 Posted September 25, 2013 Share Posted September 25, 2013 I mistakenly read subject as "R34 Winning at 80kmh" nothing to contribute Link to comment https://www.sau.com.au/forums/topic/432249-r34-whining-at-80kmh/#findComment-7035674 Share on other sites More sharing options...
gtsttrk Posted September 25, 2013 Share Posted September 25, 2013 lol, that's gold ^ Link to comment https://www.sau.com.au/forums/topic/432249-r34-whining-at-80kmh/#findComment-7035698 Share on other sites More sharing options...
fyjosh Posted September 26, 2013 Share Posted September 26, 2013 Measure the diff gear backlash and replace shims where necessary. Replace the oil. Although you could just be low on oil, it's best to do the job properly and check the clearances as the gears and shims wear over time. The pinion bearings may need replacing also, this is a bit trickier. Link to comment https://www.sau.com.au/forums/topic/432249-r34-whining-at-80kmh/#findComment-7039956 Share on other sites More sharing options...
Page34 Posted October 3, 2013 Author Share Posted October 3, 2013 ill see if it does it in other gears tomorrow on my way to work it doesn't sound to much like wheel bearings because when i load them by weaving left to right it isn't any worse what oil does it take do you know? epx 80w-90 or multitrax? Link to comment https://www.sau.com.au/forums/topic/432249-r34-whining-at-80kmh/#findComment-7050780 Share on other sites More sharing options...
Page34 Posted October 3, 2013 Author Share Posted October 3, 2013 Tested it this morning in 4th and it was still making the noise so I will top up the oil and test it out then if not I'll go further What oil do they take does anyone know? Link to comment https://www.sau.com.au/forums/topic/432249-r34-whining-at-80kmh/#findComment-7051214 Share on other sites More sharing options...
BrewsterGTS4 Posted October 5, 2013 Share Posted October 5, 2013 I had this problem with my subaru. Eg. Is the same speed. Slower barely hear it. Faster gone. I changed the gearbox and it fixed the problem. Not sure if it was the gears meshing or the pinion gear. Id say that wheel bearings make a whirring noise not wining. Snd pinion gear id guess is the front diff. So I would say possible diff relation or gearbox. Hope this info helped. Link to comment https://www.sau.com.au/forums/topic/432249-r34-whining-at-80kmh/#findComment-7052889 Share on other sites More sharing options...
Page34 Posted October 9, 2013 Author Share Posted October 9, 2013 Found out today what it was Got it up on the hoist at work and ran it up to speed Sound was comming from where the gearbox meats the tail shaft I'm guessing there's a bush or baring in there that has gone No noise comming from the box or diff Link to comment https://www.sau.com.au/forums/topic/432249-r34-whining-at-80kmh/#findComment-7057826 Share on other sites More sharing options...
