hey guys, wondering if anyone has come across this noise before
my na r34 make a whining noise at almost exactly 80km/h in 5th gear at about 1/4 throttle, it sould like i could be comming from the gearbox, cheaked oil levels and all seams fine
if anyone has heard this would love to find out what it is and if there is a fix
cheers
https://www.sau.com.au/forums/topic/432249-r34-whining-at-80kmh/
probably, how could i cheak that? would it be a lack of diff oil or something messed up internally
If it's only doing the while in one gear (e..g 5th) then you can point at the gearbox. If it's whining in whatever gear at that speed (e.g. drop it to 4th and 3rd) then it's most likely diff. Does it whine under load or all the time (e.g. lifting off going downhill)?
Wheel bearings?
Yeah that was my first though when I saw this thread. I'd say check wheel bearings, though it does sound a bit strange that it's happening in a specific gear - in terms of wheel bearings.
Measure the diff gear backlash and replace shims where necessary. Replace the oil.
Although you could just be low on oil, it's best to do the job properly and check the clearances as the gears and shims wear over time.
The pinion bearings may need replacing also, this is a bit trickier.
ill see if it does it in other gears tomorrow on my way to work
it doesn't sound to much like wheel bearings because when i load them by weaving left to right it isn't any worse
what oil does it take do you know?
epx 80w-90 or multitrax?
I had this problem with my subaru. Eg. Is the same speed. Slower barely hear it. Faster gone. I changed the gearbox and it fixed the problem. Not sure if it was the gears meshing or the pinion gear. Id say that wheel bearings make a whirring noise not wining. Snd pinion gear id guess is the front diff. So I would say possible diff relation or gearbox. Hope this info helped.
Found out today what it was
Got it up on the hoist at work and ran it up to speed
Sound was comming from where the gearbox meats the tail shaft
I'm guessing there's a bush or baring in there that has gone
No noise comming from the box or diff
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
