Hi everyone
Can I get some opinions on the cusco electronic dampening adjustment suspension for a R34 GTR Vspec 2?
Is it rubbish, or a high quality suspension? The car will be mainly for street use, the occasianal blast down the strip, and maybe 1-2 times per year on the track for a bit of fun.
I like the idea of being able to adjust the dampening easily, without having to rip out the parcel shelf.
I've run bilestien shocks with white line springs in my r33 GTS-T and they were quite nice for street but I felt I didn't have much control even though I didn't really need it for that car.
Thanks - and sorry, not a suspension expert lol.
Jono
no personal experience, but why not the bilstein PSS9 (or see if they have some even higher spec coilovers?) or go for aragosta etc...i mean, from what i've heard cusco coilovers in general are great and all, just not suited to our streets (too stiff).
Just saw a set going relatively cheap, and thought it would be cool to have the dampening adjustment in the car.
Really didn't want to have to take the parcel shelf out all the time.
Apparently Tein make an electronic set that adjust but Tein aren't that great.
And you're right - bilstein I think are excellent.
I am sure that if you look you will find a big range of people making in car adjustable damper controllers e.g. HKS, this Greddy kit:
http://www.rhdjapan.com/trust-greddy-damper-remote-control-kit-30596
and as you mention Tein. Not sure why you say Tein is not great. I have Bilstein shocks and Tein springs myself but Tein make a huge range of suspensions which are popular for both street and a big variety of motorsport applications.
Just a few comments in this forum that say that Tein isn't all that great. Not sure why.
This is what I had in mind:
http://www.rhdjapan.com/tein-edfc-active-controller-kit-70253
Its wireless, and you can add more so that each corner is controlled independently. I'd love to see how this felt
500x302xedfc_active03.jpg.pagespeed.ic.s
Edited by The Mafia
That would be awesome. Oh by the way i think i saw a 'good' set of Teins on sale on SAU/JDMST (same person) a few months ago, for GTR. Have a look. I think they were about 1500, and he'd shipped them in but never put them in his car and put them up for sale? Worth a lot more.
But hey if you saw a set going cheap then jump on them! And you could always change the springs to a softer rate!
Found them, thanks for that. I've asked him if they are still available.
Definitely don't want a hard spring rate, its mostly for street use
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
