Hi everyone
Can I get some opinions on the cusco electronic dampening adjustment suspension for a R34 GTR Vspec 2?
Is it rubbish, or a high quality suspension? The car will be mainly for street use, the occasianal blast down the strip, and maybe 1-2 times per year on the track for a bit of fun.
I like the idea of being able to adjust the dampening easily, without having to rip out the parcel shelf.
I've run bilestien shocks with white line springs in my r33 GTS-T and they were quite nice for street but I felt I didn't have much control even though I didn't really need it for that car.
Thanks - and sorry, not a suspension expert lol.
Jono
no personal experience, but why not the bilstein PSS9 (or see if they have some even higher spec coilovers?) or go for aragosta etc...i mean, from what i've heard cusco coilovers in general are great and all, just not suited to our streets (too stiff).
Just saw a set going relatively cheap, and thought it would be cool to have the dampening adjustment in the car.
Really didn't want to have to take the parcel shelf out all the time.
Apparently Tein make an electronic set that adjust but Tein aren't that great.
And you're right - bilstein I think are excellent.
I am sure that if you look you will find a big range of people making in car adjustable damper controllers e.g. HKS, this Greddy kit:
http://www.rhdjapan.com/trust-greddy-damper-remote-control-kit-30596
and as you mention Tein. Not sure why you say Tein is not great. I have Bilstein shocks and Tein springs myself but Tein make a huge range of suspensions which are popular for both street and a big variety of motorsport applications.
Just a few comments in this forum that say that Tein isn't all that great. Not sure why.
This is what I had in mind:
http://www.rhdjapan.com/tein-edfc-active-controller-kit-70253
Its wireless, and you can add more so that each corner is controlled independently. I'd love to see how this felt
500x302xedfc_active03.jpg.pagespeed.ic.s
Edited by The Mafia
That would be awesome. Oh by the way i think i saw a 'good' set of Teins on sale on SAU/JDMST (same person) a few months ago, for GTR. Have a look. I think they were about 1500, and he'd shipped them in but never put them in his car and put them up for sale? Worth a lot more.
But hey if you saw a set going cheap then jump on them! And you could always change the springs to a softer rate!
Found them, thanks for that. I've asked him if they are still available.
Definitely don't want a hard spring rate, its mostly for street use
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
