Hey guys, New to the forum.
Im in the process of buying an r32 gtr and sent out RACV to give the one im keen on a checkover and reported back all sorts of issues.
- Oil leak on front, rear upper engine
- Gearbox oil leak
- Clutch fluid contaminated/ low
- Brake fluid contaminated
- steering rack fluid leak
- Brake hoses perishing/ageing
Do you think these are all due to fair wear and tear, constant abuse or tell tale signs of something bigger?
Seller has stated that he has not done a rebuild of the motor so if I do go ahead with the purchase, is that what im in for?
Thanks for your input and recommendations
https://www.sau.com.au/forums/topic/432257-purchase-r32-recommendation/
Hi Chris,
It is hard to guess accurately, but generally those points seem to be minor and consistent with a 25 year old car.
- Oil leak on front, rear upper engine. Likely to be a cam cover seal, needs to be cleaned and replaced
- Gearbox oil leak. Unusual to be the gearbox, the engine's rear main seal is more common. This could cost a bit to fix because it will probably require the gearbox to be removed. If its not too bad leave it until the clutch is next replaced when the gearbox has to come out anyway
- Clutch fluid contaminated/ low - very common after 25 years. Probably just needs bleeding, at worst you may also need to replace the slave and/or master cylinder
- Brake fluid contaminated - just need to bleed the fluid
- steering rack fluid leak - some seal or other, or at worst recondition the whole rack
- Brake hoses perishing/ageing - very common. replace them with either rubber or braided ones.
BTW didn't RACV provide an estimate of cost for the repair as part of their report? I'd guess $1-2k to address them all if you are confident to do some of them yourself.
What isn't on that list is rust, smoking engine, rough running engine, bent suspension etc etc, they are all the expensive things!
Hi Chris,
Thanks for your reply mate.
Nah no cost estimate for fixing all those things. Just says recommended getting quote to fix before purchasing.
The report said the rear quarter panel may have rust but needs an expert to see it and give a conlusion as the report was inconclusive. Apart from that the tester said the car was good
With the RACV check over, do you just give them a call, tell them where the car is and they sort everything from there?
Yeh give them a call and location, car and theyll send someone out. In the case of this, the guy needed to take it to an assessment Centre to be assessed
  • Like 1
Too true.
I know you're new, but no need to post the same thread in two sections;
http://www.skylinesaustralia.com/forums/topic/432256-buying-r32-gtr-oil-on-motor-issues/
They're tough cars but an R32 GTR being a 25 year old high performance car is bound to have multiple issues unless the previous owner spent big dollars on it before you got it. (and even then) Like the person in the duplicate post has already stated - be ready to sink a few thousand more into it after you get one. Especially if you're planning on driving it hard. No one buys one just to drive to the milk bar and back on Sundays.
As someone on here once said. If you can't afford to buy two GTR's, you can't afford to run one :)
  • Like 2
That's so true.... :woot::woot: :woot: :woot:
But sometimes it's more like ' if you can't afford two houses, you can't afford one moddified gtr '
  • Like 1
I dont have two houses...... thats why I have a modified GTR hahaha.
  • Like 1
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
