hi guys
i no this is proble the wrong area but i am after a simple easy to use program to cut and make videos,
i am new to this be am a good learner.
example for what i am after is - i have 3x 3 min videos and only want to use bits from each clip to make one.vid.
is there any easy program to use/ download ? mostly using cips from my go pro.
thanks
and sorry if in wrong area
https://www.sau.com.au/forums/topic/432269-video-edit-programs/
Anyone got some free software that's a little more advanced? I have been using VideoPad Pro, but the video and audio not syncing properly is really shitting me these days. Too much stuffing around to get it to match up again. I also tried Wondershare, and while I like the effects it has, it doesn't have many good transitions. It also puts a watermark on finished videos unless you upgrade to the Pro version, but don't wanna pay for it when I'm not totally happy.
Anyone tried Lightworks? Have heard it's outrageously complicated to use. Would rather something a bit simpler, but with lots of options. Any suggestions?
yeah i was just after a program to cut and chop my go pro clips and ad music over lay and or words - i have played with a few and none really have all the features just bits.
its only for me at home and to chuck on youtube not a pro movie maker - any recommendations?
Hey mate,
I use Adobe Premier, and Adobe After Effects CS6.
I am aware they aren't free, but you can download a trial version if you've just got one or 2 videos to do. I wouldn't say they are SUPER HARD to use, but they are definitely more advanced then your basic Windows Movie Maker / iMovie.
For reference, I pay $50 a month for all Adobe Software. Cheap as chups.
Cheers,
Shaz
  • 11 years later...
    • I've watched some vids and the technique seems to be to butt the sheets up to one another and use MIG to spot weld and slowly fill in the spots until its eventually all sealed. No runs as you would normally do, as there's too much heat generated that way. Yeah my stick welds are terrible these days because its been so long since i've done any of it. I expect to be spending many hours practicing
    • I have personally seen a Tomei USA RB26 cam that didn't even fit the head. Kind of nuts to me that it was even possible for that to happen but such is life.  There's two UP Garages in the US. One is a US branch of the Japanese company which sells things they brought over at tremendous markup. The other is University Place Garage/Fairlady Motors which is a shop best known for putting VCAM in RBs and trying to convince people to stop putting in 800hp of turbo on a 2.5L motor.
    • Gasless MIG is not exactly suited to what I would call "delicate" or "attractive" welding. So I would rule it out for sheet metal rust repair type stuff, unless you're only doing it in hidden places. I'm thinking about getting myself a gasless MIG for "hack together" type work. Noting that my welding experience is very very low, and quite a long time ago. So I'm also looking for "simple", but I'm not expecting "excellent". I'm not even sure that proper MIG is the best for sheet metal work. I get the feeling that the degree of control and the minimisation of heat input that you get from TIG is probably what you really want. And then you have to get good at doing it before the welds won't look like a monkey flinging a handful of shit anyway. You're probably SOL for an easy and cheap way to get from where you are to where you want to be. Much like myself.
    • Any recommendations for what would be the easiest welding type to start on, for sheet metal rust repairs and maybe some exhaust piping too? Seems like MIG is the most common. Would gasless MIG be ok to learn on and do some simple jobs? I have a stick welder which has a Lift TIG setting, but i'm more interested in getting whatever's easiest to do, and most suitable, rather than using what i have.
    • Is the UP Garage in the US of Ayyeee even the real UP Garage?
